Old 10-12-2011, 10:47 AM   #8
whiterps13
whiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to behold
Originally Posted by jaysgottaredtop View Post
the fact that he's asking shows that he probably doesn't want to be yet another stance SNIP with 205s stretched and cambered to "fit"
lower the car, zero out camber. 17x9 +25 will allow for some beefy tires on stock fenders. 235/40 or 245/40 front, 245/40 or 255/40 rear. and if needed (depending on your tires/coilovers), small slip-on spacers up front for clearance.
go forth into the world and prosper.
Yeah, zero camber is so awesome bro.
17x9 +20 will barely clear coilovers on almost any setup, it even rubs on some coilovers. Put 245/255 tires on there, and reduce clearance by 5mm, and its going to rub. Why search for wheels that require spacers, when the ones you have currently will work?
whiterps13 is offline
