Old 10-12-2011, 01:25 AM   #1
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
Two built engines (RB25det and Mazworx sleeved SR20det) and TONS OF OTHER PARTS!
1. NO BASHING PRICES OR PARTS! if you dont like it, please leave!
2. If you PM, please also bump the thread.
3. Im always adding more parts and pictures to the thread, so check back every so often.
4. More parts have been added as of...10-12-11
I don't need to sell the engines and parts, I am only doing it to speed up my other projects...so don't bother lowballing me.
Mazworx SR20DET Engine- I WILL NOT PART OUT THIS SR!
HEAD-
New SR20DET Head- $500
Stage 2 Port and Polish- $800
Polished Combustion Chamber- $210
Full Radius Valve job- $200
Tomei Intake Cam Gear- $200
HKS Exhaust Cam Gear- $200
Tomei Solid Lifters- $280
Tomei 270 Cams- $600
Brian Crower Springs and Titanium Retainers- $220
Supertech Valves- $300
HKS Rocker Arm Stoppers- $100
SR20DET Powder Coated Valve Cover- $150
Greddy Oil Cap- $80
New Muli-layer Exhaust Gasket- $80
New Cam Angle Sensor- $330
New Rocker Arms- $150
BLOCK-
SR20DET Redtop- Cost of a core block- $100
CP Pistons 86.5mm 9.0 CR- $525
Golden Eagle Sleeves- $375
Manley Turbo Tuff Rods- $725
Calico Coated ACL Race Bearings- $210
ARP Main Studs- $185
Balanced & Polished Crankshaft- $200
ATI Crank Pulley- $425
Greddy Oil Pan- $300
New Water Pump- $65
New Oil Pump- $375
Upper Oil Pan- $50
Sleeving- $280
Bore/Hone- $320
Whatever I Forgot- $X
TOTAL= $8,535.00+
ASKING= $5,000 OBO if you disagree with my price, either make an offer or go have Mazworx build you the same engine and see what the price ends up being.
PHOTOS:
RB25DET Engine- I will part out some of this setup now, due to my friend needing some of the parts.
R33 Rb25 series II~15k miles since rebuilt- $2,000 obo (just with the arp, tomei hg, and new bearings it is about 800 in parts)
Arp head studs
Arp main studs
Tomei triple metal head gasket
Greddy intake manifold w/ q45 tb- SOLD!
Greddy exhaust mani ceramic coated- $850
Precision 5557 t3 t4 turbo- $650
Mcckinny mounts- $300
Rb20 trans- $200
Competition stage 4 6 puck clutch- $300
Has 4/6 spitfires that come with it- make offer
Waisted spark assembly- make offer
rb25 to s13 Engine Harness w/ ecu- make offer
rb24 to s13 driveshaft- $250
6 370cc injectors- $150
OTHER PARTS
TurboSmart Megasonic Blow Off Valve
- ~1-2k miles
- $150 + shipping
Kisuu Custom Made Fuel Rail
- NEVER USED
- $150 + shipping
S15 Hoods
- NEVER USED
- $250
ETS Custom Made Intercooler 24X8X3
- NEVER USED
- PERFECT SHAPE
- $175
Greddy Intake Manifold Modifide and Comes w/ Q45 (90mm) Throttle body
- Roughly 500 miles
- PEFRECT SHAPE
- $600
Unknown Brand BOV
- Slightly Used
- PERFECT SHAPE
- $50
ROSS TUFFBOND Water Pump Pulley
-ONLY MOUNTED
-PERFECT!
-$100
S14 SR20 88.5mm Cometic Metal Head Gasket multilayer
- NEVER USED
- PERFECT SHAPE
- $70
OEM SR20VE Valvetrain (IN+EX Valves, Springs, Cams, Gears)
- 15,000 Miles
- PERFECT!
- MAKE OFFERS ON WHAT YOU NEED!
S14 Non-ABS Driveshaft
- Used
- $120
S13 Non-ABS Driveshaft
- Used
- $120
S13 SR Transmision - SALE PENDING
- Roughly 30k miles
- PERFECT SHAPE
- $150
These are all the make an offer items...i dont want or need them all so just make an offer...pictures of these upon request...its to many pictures for the thread.
S13 SR OEM Coil Pack Cover
BNIB SR Multi Layer Exhaust Gasket
BNIB OEM SR Exhaust Gasket
SR OEM Exhaust Manifold w/ Heat Shield
(1) V1 Godspeed S13 Toe Arm
(1) V1 Godspeed S13 Traction Rod
Valve Cover Gasket
Valve Cover Coil Plug Gasket
Water Outlet
Water Inlet
(4) Cam Oil Tubes (2 Sets)
(16) OEM Spring, Retainer, and Keeper (1 set)
(8) SR OEM Intake Valves (1 set)
(8) SR OEM Exhaust Valves (1 set)
(8) SR OEM Rocker Arm (1 Set)
(8) SR OEM Lifter (1 Set)
SR Block (bare) w/ 87mm bore (needs align bore...roughly 200 at any machine shop)
SR20 Front Cover w/ Oil Pump
(2) Oil sandwich plate Galley w/ sensor
(2) Upper Oil Pan
(2) Water Pump
Water Pump Pulley
(3) Rear Crank Case Cover
Crank Pulley
(4) SR Oil Squirters (1 Set)
(3) SR OEM Rod
(4) Upper Oil Pan Screen (2 Sets)
(3) Different SR20 Timing Chain Guides
(3) SR Timing Chain Tensioner
(2) SR Main Cap Girdle
(2) Alternator Bracket
AAC Valve
(3) Knock Sensor
(3) Coolant Tubes
(2) Thermostat Housing
(2) Coolant Temperature Sensor Housing
3” S14 Exhaust that was very hacked up but it has a Very good condition HKS muffler
Turbo Blanket (was on a T67)
SR Transmission Plate
SR OEM Turbo Lines
S13 Rear OEM Chamber Arm
S13 Rear OEM Traction Arm
S13 Rear OEM Toe Arm
stock KA24de fuel pump (in working order)
stock KA24de header + stock heatsheild
stock KA24de airbox intake system and Filter is still clean
Summit Liquid Fuel Pressure Gauge
Thank You For Looking!
https://instagram.com/eck_matthew/
Imarvin240 is offline
Old 10-12-2011, 05:23 AM   #2
xFix Kaos
xFix Kaos is an unknown quantity at this point
im gonna bump the shit out of this, so correct me if read it wrong...5g for the whole rb setup? is that turn key? or what else u need to complete swap?
xFix Kaos is offline
Old 10-12-2011, 05:26 AM   #3
xFix Kaos
and it wont let me PM me...buttttttt if the rb25 is still in a running car, il trade you my running 240 s13 sohc 5speed with ksports plus cash, this way u can have another running project and i dont gotta spend my weekend swapping em lol =)
Old 10-12-2011, 08:26 AM   #4
Angronrb25
Angronrb25 is an unknown quantity at this point
Would you be willing to sell just the Q45 throttle body with adapter plate? Also would like the T67 turbo blanket!
832-428-9673
Thank you
Leonidas
Angronrb25 is offline
Old 10-12-2011, 09:10 AM   #5
Imarvin240
Trader Rating: (18)
you shouldn't need anything else.
just looking for money right now...also, is this Todd?
832-428-9673
Thank you
Leonidas
i had the greddy manifold modified with a larger flange welded on, but i do have a couple other Q45 throttle bodies i can sell...no flanges though.
Old 10-12-2011, 09:53 AM   #6
SLEEPYDUB2
SLEEPYDUB2 is an unknown quantity at this point
So you have 4 out of the 6 spitfires?
Is it series 2?
SLEEPYDUB2 is offline
Old 10-12-2011, 03:45 PM   #7
xFix Kaos
o danmn, so tempted....and nah not todd names brian
Old 10-12-2011, 03:47 PM   #8
richrosco
richrosco's Avatar
Trader Rating: (51)
richrosco is an unknown quantity at this point
Feedback Score: 51 reviews
SR
bump for a bad ass sr20det build, I have almost the same build, I hope people understand how huch it actually costs to BUILD a motor, not cheep bolt ons.
richrosco is offline
Old 10-12-2011, 08:05 PM   #9
mando240
mando240 is an unknown quantity at this point
How much shipped to 33177
mando240 is offline
Old 10-12-2011, 08:39 PM   #10
93smallblock
93smallblock's Avatar
93smallblock is an unknown quantity at this point
Since you will part out the RB would you be willing to sell the alternator pulley?
93smallblock is offline
Old 10-13-2011, 07:48 AM   #11
lkp_s13
lkp_s13's Avatar
lkp_s13 is an unknown quantity at this point
Really need to buy a set of cam oil tubes and the set of engine oil squirters. Can you pm me a guesstimate. $ 65 shipped?
lkp_s13 is offline
Old 10-13-2011, 08:02 AM   #12
powerdbyRB25
powerdbyRB25's Avatar
powerdbyRB25 is an unknown quantity at this point
Hey can you pm me more pics of greddy rb25 exhaust Mani and how much are you trying to get for it. Thanks
powerdbyRB25 is offline
Old 10-13-2011, 08:15 AM   #13
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Don't think I missed it, what's the mileage on the SR20 since rebuild? Willing to part block from head? If yes, PM me shipped price to 53081 for the built block.
VNG704 is offline
Old 10-13-2011, 08:28 AM   #14
Cypher02xd
Cypher02xd is an unknown quantity at this point
are you willing to seperate that 5557 precision? if so for how much?
Cypher02xd is offline
Old 10-13-2011, 02:20 PM   #15
redline elite
redline elite's Avatar
redline elite is an unknown quantity at this point
PM me, how much for hood shipped to 30076 roswell GA
redline elite is offline
Old 10-13-2011, 02:27 PM   #16
95s14rb25
95s14rb25 is an unknown quantity at this point
pm me a price for the turbo manifold rb25
95s14rb25 is offline
Old 10-13-2011, 04:46 PM   #17
WhipsGoneWild.net
WhipsGoneWild.net's Avatar
Trader Rating: (18)
WhipsGoneWild.net is an unknown quantity at this point
Where at in pa r u? Im interested in turbo setup lmk will be at droptoberfest this weekend
WhipsGoneWild.net is offline
Old 10-14-2011, 01:41 AM   #18
Godfoot
Godfoot's Avatar
Godfoot is an unknown quantity at this point
Send a message via AIM to Godfoot
how much for the stage 4 clutch, ive got family in pa so i can pick up anytime
-WTB: Zenki Lip.....true art died in the heart of my mind - BLU
Godfoot is offline
Old 10-14-2011, 07:20 AM   #19
Blackerninja
Blackerninja is an unknown quantity at this point
Would you split the head? S13 SR?
Blackerninja is offline
Old 10-14-2011, 02:55 PM   #20
Imarvin240
Trader Rating: (18)
okay, im sorry, but i am getting PM'd this to much so im going to set things straight since its not clear enough above...guys, im not splitting up the SR...its staying as a complete long block (including the ati pulley). The rb25 is also staying as a complete long block. Only bolt-ons are being removed from the engine (manifolds, turbo, transmissions, ect). also, if i don't have it listed in my large list of things for sale...i probably don't have it.
Old 10-16-2011, 05:23 PM   #21
Imarvin240
Trader Rating: (18)
bump bump bump!
Old 10-17-2011, 09:24 PM   #22
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
payment sent for timing chain tensioner. bump for great prices and accomadating my urgency for the part.
sidewaysil80 is offline
Old 10-18-2011, 02:32 AM   #23
lkp_s13
lkp_s13's Avatar
Whats your paypal?
lkp_s13 is offline
Old 10-19-2011, 02:37 AM   #24
TheRealSy90
TheRealSy90's Avatar
$200 for the greddy oil pan and one upper pan. Just destroyed my greddy on a pothole...
Such a good signature.
TheRealSy90 is offline
Old 10-20-2011, 07:38 AM   #25
Imarvin240
Trader Rating: (18)
guys, i have stated in enough places that the engines are not being parted out.
Old 10-20-2011, 08:25 AM   #26
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
hey man could you post more pics or the greddy turbo mani please.
P-Funk alot is offline
Old 10-20-2011, 07:01 PM   #27
bustitsideways
bustitsideways is an unknown quantity at this point
id take the whole bottom end but if you ant gonna part it out then o well i need a xtra race block next weekend
bustitsideways is offline
Old 10-21-2011, 03:51 AM   #28
silviatp23
silviatp23 is making a name for him/her selfsilviatp23 is making a name for him/her self
What does the kisuu fuel rail fit? Are those injectors for sale too? How much what size?
silviatp23 is offline
Old 10-21-2011, 05:48 AM   #29
DallasTXjdm
DallasTXjdm's Avatar
Trader Rating: (41)
DallasTXjdm is an unknown quantity at this point
Feedback Score: 41 reviews
damn I wish I had some cash - ***bump***
DallasTXjdm is offline
Old 10-21-2011, 06:21 AM   #30
TheRealSy90
It's a bolt on to me but ok.
