Old 10-10-2011, 10:52 AM   #1
Z-Fever
Z-Fever is an unknown quantity at this point
Z-Fever's VQ35 wiring solution, cool video!
The VQ35DE is one of the most popular engines Nissan produces. It came in 10+ vehicles worldwide and because parts are readily available off the shelf at your local parts store it makes swapping it into your S-chassis a little more desirable than the JDM choices out there.
About 5 years ago we here at Z-Fever did our 1st VQ35 swap into an S13. We had to use an AEM stand alone and that wasn't cheap. We also had to change the stock drive-by-wire throttle body out for a cable driven unit. Doing this was pretty expensive.
Since then we have worked to develop a cheaper solution for our customers and we finally figured it out about 3 years ago. Here is a video of our tuning solution in action:
VQ35DE Motor with Z-Fever tuned ecu. Standalone run, all security bypassed. - YouTube
We use the stock OEM 350Z ECU, harness, and accelerator pedal.....
We also need the pedal's connector and an OBD-II connector from an 03+ Nissan vehicle.
You send us that along with the S-Chassis' upper and lower harness and we wire it all up and send it back to you looking like this:
From there, you can install it......
Here is Z-Fever's S14 that is running a twin turbo VQ35 engine:
Z-fever's S14 drift car w/ VQ35 twin turbo on dyno.MOV - YouTube
Z-Fever's S14 drift car tandem w/ Rob Flemming.MOV - YouTube
If you need any help with your VQ swap we can help. Let us know.
Also check out Services-Engine Swaps- VQ35DE
Thanks
Doug
Z-Fever, Inc 813-877-7600
www.zfever.com or www.VQ35swap.com
Z-Fever is offline   Reply With Quote
Old 10-10-2011, 10:55 AM   #2
victorw210
victorw210 has made poor choicesvictorw210 has made poor choicesvictorw210 has made poor choicesvictorw210 has made poor choicesvictorw210 has made poor choicesvictorw210 has made poor choices
how did you bypass the secuity? is it a chipped ecu to remove the nats system
victorw210 is offline   Reply With Quote
Old 10-10-2011, 07:02 PM   #3
revcyanide
revcyanide's Avatar
revcyanide is an unknown quantity at this point
I was literally JUST looking into this 5 min ago!
any special discounts for us Zilva members on wiring harness and NATS service?!
Originally Posted by Blackzenki82 View Post
bring da ruckus to dat ass with the braaaaaaaaaassssssssssssshhhhhhhhhhh
revcyanide is offline   Reply With Quote
Old 10-10-2011, 11:36 PM   #4
sexcii-zenki
sexcii-zenki's Avatar
sexcii-zenki is an unknown quantity at this point
will the tach and speedo work?
sexcii-zenki is offline   Reply With Quote
Old 10-13-2011, 05:16 AM   #5
irax
irax's Avatar
nope, you can modify the factory tach to read 6cyl.. and speedo does not work without some work into it
irax is offline   Reply With Quote
Old 10-13-2011, 06:20 AM   #6
Z-Fever
To answer the question, No the Z-Fever VQ35swap harness solution will not also manage the speedo, tach, or other gauges. Not just with this harness service but we have figured out how to make them work already. It takes a few things.
We use an MSD tach adapter to change the signal and then another sign wave adapter to convert it again and adjust the tach signal to be accurate.
As for the speedo, the newer cars use the ABS system to acquire the speed signal. It then goes through the ECU's CAN-BUS system then to the speedometer.
If your car does not have ABS then you need to get a rear diff that does like a J30, Z332, S15, R32, etc... and install it. Then we make a wiring harness that powers up the ABS sensor on the diff and use a square wave adapter to convert that signal to what the speedo needs and adjust it accordingly so that the speedo is accurate.
This is what our harness looks like. It only requires someone to hook up 3 wires.
Old 10-13-2011, 06:28 AM   #7
sexcii-zenki
o ok so not included with that price...
Old 10-13-2011, 06:35 AM   #8
Z-Fever
The cost is reasonable considering the newer technology in the VQ35. And it is still a ton cheaper than running an AEM or other stand alone. If you run stand alone you STILL have to address the speedo, tach, and gauges. So this might be too expensive for your personal budget (understandable if that is the case).
However, if you are someone that has made the decision to do a VQ35 swap then our harness solutions and ECU tuning solutions are the best value in the marketplace for this swap.
Old 10-13-2011, 07:24 AM   #9
fullthrottle
fullthrottle's Avatar
fullthrottle is an unknown quantity at this point
Notice that its only 500 bucks for the wiring...... o yea but did we mention its 450 for nats removal? wtf? 950 bucks for a stock tuned ecu? I mean i realize you guys need to recoup the cost of the R&D to accomplish this task but thats pretty steep. Is the ecu tuneable for twin turbo applications or bolt ons?
fullthrottle is offline   Reply With Quote
Old 10-13-2011, 07:57 AM   #10
vas570sx
vas570sx's Avatar
vas570sx is an unknown quantity at this point
These guys are legit, and do awesome work.
I met you guys at the Honda Grand Prix drift demo driving this carvvv
vas570sx is offline   Reply With Quote
Old 10-13-2011, 08:25 AM   #11
Z-Fever
It is what it is. $950 to wire it up turnkey ... We actually pay Uprev $250 per license since we use their software to tune the ecus... so all in all you are getting a harness service and a tune on your ecu for this price... Not bad when you consider that we charge $600 to do a NA tune on a 350Z, and we do them quite often.
Besides that... this harness service required a LOT of time on my end to figure out when I was not making a dime for the shop. We are the only ones that do it so we can dictate the price. I think it is reasonably priced for what you receive... Hook up battery, ground, ignition you are ready to go... or go get a AEM for $1600 a harness for $1100 and a tune for $500 ... you are over $3K that way.
Z-Fever
Old 10-13-2011, 08:42 AM   #12
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
You need to pay to be an advertiser here
Old 10-13-2011, 08:43 AM   #13
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Nice product! If I can give any advice, simply dimiss half the flack from people saying it's 'rpciey' or 'that's it?!?' as 95% of them can't afford to even do the swap in the first place...
Old 10-13-2011, 08:47 AM   #14
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
Doug does good work, here's a teaser of the roommates setup running a z-fever harness. He helped us through the phone and email figure out small issues that we were having. Even let us ship the harness back out and check it out again for us, made a video of our ecu running a stock 350z and overnight ed the parts for us.
2011-10-07_16-17-35_836.mp4 video by punxva - Photobucket
Slip Gypsies Blog
not sure if you realize this
Old 10-13-2011, 09:05 AM   #15
sexcii-zenki
ok so if i wanted to send you both my harnes since i want to keep the abs and fully functional cluster w/obd port...how much would you charge just make the harness? without flashing the ecu ill do that on my own
Old 10-13-2011, 09:48 AM   #16
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Any plans to "beautify" the harness in the future? I love the price and i love the service that you are providing to people, but in my personal opinion the harness looks pretty jank.
Old 10-13-2011, 10:01 AM   #17
Z-Fever
That top one is our test harness we use around the shop. The ones customers receive are loomed all the way up... look oem.
We are getting in touch with admin for advertising btw.
Z-Fever
Old 10-13-2011, 10:27 AM   #18
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Z-Fever
Oh, right on. Disregard what i said then.
Old 10-13-2011, 03:30 PM   #19
irax
irax's Avatar
how much for this?
