Old 03-25-2004, 08:18 PM   #1
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
check for vacuum leaks as well. especially to the brake booster and sometimes that check valve thats inline from intake manifold to brake booster fails, if your pedal becomes immediately stiff after you turn off the car then that is the problem. good luck man, me and my friend did a brake job with speed bleeders and it worked without a hitch, maby they arent tightened down enough?
INeedNewTires is offline   Reply With Quote
Old 03-25-2004, 08:36 PM   #2
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
Take off the speed bleeders. Bleed again. If you still have problems do a search on how to bleed brake system in case you're doing it wrong.
-Juan
240Stilo is offline   Reply With Quote
