Old 10-26-2011, 11:10 AM   #1
Wbarnes13
Wbarnes13 is an unknown quantity at this point
SPL Monoball Bushings
Hello everyone. I have been searching around looking for reviews or anything I could find on the SPL rear knuckle monoball bushings http://www.splparts.com/chassis-S14.html#SPLRKBS13. I was just wondering if there okay for daily driving or if rain and dirt and such would hurt them. I'm looking to replace them for my ES bushings I have now to get rid of the binding. Would they be better then ES for daily driving?
Wbarnes13 is offline   Reply With Quote
Old 10-26-2011, 11:29 AM   #2
boyou2
boyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura aboutboyou2 has a spectacular aura about
for a DD, you should go with an ES kit
boyou2 is offline   Reply With Quote
Old 10-26-2011, 01:04 PM   #3
Wbarnes13
I have the ES kit now and they are binding after only 5 months. I have thought about the zerk fittings but have read a few things about them not working to well either.
Old 10-26-2011, 01:21 PM   #4
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
I ordered them for my S13. A friend of mine pretty much daily drives his Z33 with full SPL arms and spherical bearings on everything. They're not as bad as some people make them seem. With a good set of shocks/springs (er, coilovers), you won't really notice them.
As far as durability goes, we just spray them down with lithium grease once a month and they hold up just fine. Then again, we're in California. Only thing we really have to worry about is dirt/dust.
-Jspec-
Instagram/CrimsonRockett
Old 10-26-2011, 01:47 PM   #5
Chaluska
i'm running ES bushings in most of the car, and it is ultra tight (not rough, just tight).. just make sure you lube the crap out of them before installing. Mine had about a 1/16th" thick layer of grease before installation.
Old 10-26-2011, 01:56 PM   #6
boyou2
6months for me, nothing to notice....
Old 10-26-2011, 02:11 PM   #7
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
i have SPL's first made suspension completely around all corners even the lower control arms, i use to daily my s13 for about 2 years and its been sitting out back in the yard with winter storms for 2 years now. haven't had a issue yet. no rust buildup either when i checked it a few days while i was swapping out my turbo manifold to a new one.
good for the money
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 10-26-2011, 02:32 PM   #8
GSXRJJordan
GSXRJJordan's Avatar
I recommend that kit for anyone, regardless of purpose. For max performance, there should be no compliance in anything except the shock - that actually helps the shock do it's job better. Crappy bushings will make a bad shock feel smoother over high speed stuff, but a good shock will actually feel more comfortable with sphericals all around.
We currently sell that kit, and can install it for you as well. Give [email protected] an email, our SPL pricing is tits.
Old 10-26-2011, 02:36 PM   #9
azndummie
azndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant futureazndummie has a brilliant future
These are not bad at all, they dont make as much noise as everyone thinks and they make the car feel SOLID in the rear.
azndummie is offline   Reply With Quote
Old 10-26-2011, 03:05 PM   #10
Wbarnes13
I lubed the hell out of them when I installed the ES, and now every time I take off you can hear the whole rear squeaking. I jacked the car up and tried to move the whole knuckle with a pry bar and it didn't move very easily. Thanks for all the input it's much appreciated I think I'll try out the SPL's.
Old 10-26-2011, 03:17 PM   #11
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I've got the DefSport/Skullworks in my Z32 uprights, and love them. As JordanInnovations pointed out about, the most comfortable suspension is one where the shock setup takes all of the work, not the bushings binding. My 240 rides so nice with them, that it's hard to ride in other ones.
Old 10-26-2011, 04:10 PM   #12
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
same here
been running them for over a year now
and really like the performance and feedback from the suspension
I raise the rear of the car and everything just moves down smoothly
I can move the corners freely
I'm running them on Zeal Function XS coilover, Powertrix traction and toe arms and Peak Performance RUCAS. Progress swaybars.
do note though that spherical will requires more maintenance as has been pointed out
I clean them up with lubricant every other month or so
but their lifetime will be less than rubber or poly
also more feedback = more harness, noise, vibrations aswell
you will feel imperfection in the road more
and your shitty coilovers will be exposed
overall, I'm very please with them
track car? highly recommended less regulations dictate otherwise
Old 10-27-2011, 12:47 AM   #13
JDMStanced
JDMStanced is an unknown quantity at this point
i just installed ES bushings for inner and outer bushings on my z33.
the car still squeaks like a mutherfu** when i brake.. even i lubed everywhere
JDMStanced is offline   Reply With Quote
Old 10-27-2011, 12:52 AM   #14
boyou2
i did'nt lube anything, and no squeaking ^^
Old 10-27-2011, 12:54 AM   #15
JDMStanced
do you have z33?
Old 10-27-2011, 02:32 AM   #16
Howie Felter Snatch
Howie Felter Snatch's Avatar
Howie Felter Snatch is an unknown quantity at this point
What is this squeaking you people are talking about? I have full ES bushings everywhere (RED type) and I've never heard any of this squeaking.. I've even have set up 3 other S13's with full ES bushing kit and never heard this before..
Can sound please take a moment to explain this to me and why this would happen in the first place and how loud does this squeaking get? I got SPL/PBM arms all around with TEIN coilovers.. Does it just depend on what type of arms/coils you're running?
Personally I think the ES bushings are awesome! They definitively tightened up the rear/front end a ton!
Howie Felter Snatch is offline   Reply With Quote
Old 10-27-2011, 05:23 AM   #17
Wbarnes13
I'm just worried about rusting. I'm guessing if I just take the time to lubricate them I shouldn't have to worry about rust. And about to squeaking for the first few months it was fine. Just over the past few weeks I've been hearing it every time I back up or take off.
Old 10-27-2011, 06:42 AM   #18
boyou2
Originally Posted by JDMStanced View Post
do you have z33?
no I got an s13
Old 10-27-2011, 08:58 AM   #19
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
grease breaks down with water and grime over time or get squeezed out
starts low but sound get worse and worse with time
I think that the heim in your arms are probably helping avoid the squeak
it's more apparent when the ES bushings are installed on both the upright and arms
I agree, when they are well lubricated and functioning properly
they liven up the car
on the other hand, when they fail it can be ugly....
Old 10-27-2011, 09:50 AM   #20
Pandapants
Pandapants's Avatar
Pandapants is an unknown quantity at this point
Send a message via AIM to Pandapants
Good grief, was that from binding?
Pandapants is offline   Reply With Quote
Old 10-27-2011, 10:14 AM   #21
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
pretty much
friend came to the shop complaining about a possible bent shock
went over a pothole and rear started clunking really bad
drove like that for a couple of days before coming by too
replaced it with another ES bushing we had on hand...
btw
you guys do know that difference between the red and black ES bushings right?
black ones are graphite impregnated to self lubricate, red ones aren't
ps forgot, this thread has some useful information aswell:
http://nissanroadracing.com/showthread.php?t=3191
Old 10-27-2011, 10:21 AM   #22
Zenki_516
Zenki_516's Avatar
Trader Rating: (30)
Zenki_516 is an unknown quantity at this point
Feedback Score: 30 reviews
If anyone is worried about squeaking or binding, just buy the bushings in BLACK. The black ones lubricate themselves while the red ones dry out over time. And you should spray any ES bushing with white lithium grease every so often to prevent either from happening.
Edit: Was typing while that^ was posted, but read it twice... black are self lubricating.
Still Thug.
Originally Posted by ka-titties View Post
i'm from Florida so i'm retarded....
Zenki_516 is offline   Reply With Quote
Old 10-27-2011, 10:33 AM   #23
JDMStanced
what the hell!! i asked the vendor and he said red and black are the same thing. That's why i ordered red...Does the red perform better or something?
THe reason i replaced my LCA inner and outer bushing on my z33 is because of the squeaking and clicking noise i had. ES bushings didn't fix it..hmm..
Old 10-27-2011, 10:36 AM   #24
Zenki_516
Zenki_516's Avatar
Trader Rating: (30)
Yea he definitely lied, or didn't know what he was talking about. I've never heard anything as far as one performing better. I think red is just red for looks.
Still Thug.
Old 10-27-2011, 01:16 PM   #25
boyou2
that's why mines don't sqeeze, I took black ones ^^
Old 10-27-2011, 01:23 PM   #26
word sux
word sux's Avatar
word sux is an unknown quantity at this point
yea idk why they even make the red ones its pointless and most vendors do not know that they are different
word sux is offline   Reply With Quote
Old 10-27-2011, 02:59 PM   #27
JDMStanced
I emailed concept z performance where I got the bushings.
this is his reply"The Black Bushings are impregnated w/ Graphite, but we have to lube them also.* Both Black and Red* squeak if they are not lubricated."
am I suppose to just live with the squeaks? it's f ing loud. idk if my camera can catch the sound but I'll try to make a vid of the sound.
Old 10-27-2011, 03:25 PM   #28
codyace
codyace's Avatar
Trader Rating: (58)
The black bushings being impregnated with graphite is NOT across the board at all, and is a function of the newest stuff IMO. I've got some black bushings in the past in kits that actually were mistakenly put in 'kits' and they were all the same stuff visually.
Old 10-27-2011, 03:29 PM   #29
rage
rage is an unknown quantity at this point
Send a message via AIM to rage
so, the black ones don't have the binding issue?
rage is offline   Reply With Quote
Old 10-27-2011, 03:39 PM   #30
JDMStanced
I feel like I'm ripped off now..
