Old 11-19-2011, 05:38 PM   #1
shinjitsu
shinjitsu is an unknown quantity at this point
Diy: Installed Nrg Grounding kit mod and Hotwire ignition Mod on 240sx
This weekend i did some mods to my car. I thought i would do a little review on these stuff to let you guys know if they even do anything. It was the Nrg Universal grounding kit that you can get online for about $50 and the hotwiring ignition mod is just the materials needed to splice the wires together.
First off the Nrg Grounding kit was very simple and i put it together in 30 mins. Basically it just adds ground wires to the battery to help it charge and theoretically improve your electrical system by allowing it flow better with more ground points. It says it would improve idle, electrical stuff and all that junk. IMO it barely improved at all. Maybe its because i have good ground points already but adding 6 more ground points did not really do much. So that concludes that getting a grounding kit is a waste of money. If you need more than one ground point just make it yourself.
Now about the hotwire ignition mod, This is the cheapest and most beneficial mod to do to improve your throttle response. By putting a relay between the ignition coil power wire, your sending 12v straight from the battery to the ignition coil. This gives a constant spark all the time which is really good if your getting less than 12volts on your ignition coil. I received better and snappier throttle response and even better idle.
here are some pics.
So if you cant afford getting a msd ignition system, i would recommend doing the ignition hotwiring mod.
shinjitsu is offline   Reply With Quote
Old 11-19-2011, 05:48 PM   #2
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
A grounding kit is not a waste of money on a rusting corroded car. It all depends on what you are doing, and what climate you live in.
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 11-19-2011, 06:22 PM   #3
!Zar!
!Zar!'s Avatar
Throw that thing away.
Old 11-19-2011, 06:25 PM   #4
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
Great stuff. I'll buy 1000 feet of wire from home depot for $10 and wire up 100 cars, or maybe I'll put 1000 feet of wiring inside 1 car to unleash 200whp by charging up electron flow from Alternator to Battery.
Seriously, why would battery matter?????? Doesn't power come from Alternator when car is running which is direct ground through the housing of alternator to engine.
Loops and loops of unnecessary wires.
Had to write this out. Seeing cars like this angers the shit out of me. Just wanna rip all that shit out and melt it into a turbo or super charger.
Hashiriya415 is offline   Reply With Quote
Old 11-19-2011, 06:31 PM   #5
shinjitsu
its not about the battery, its the grounds that the alternator needs for charging the battery.
Old 11-19-2011, 06:53 PM   #6
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
racecar
just saying
#0191 "Lin'da" 2AMR>2AMR>
Originally Posted by Bambi View Post
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 11-19-2011, 06:54 PM   #7
jacobs13
jacobs13's Avatar
jacobs13 is an unknown quantity at this point
Really? 1000ft for $10? Maybe you should know what your talking about before you try and shit on someone. The battery matters quiet a bit, the alternator just charges the battery for it to be able to supply all that power to your car for long periods of time. Even though the kit is a little much, theres nothing wrong with some extra grounds.
jacobs13 is offline   Reply With Quote
Old 11-19-2011, 07:09 PM   #8
G5SR20240
G5SR20240 is an unknown quantity at this point
Ignorance is bliss
G5SR20240 is offline   Reply With Quote
Old 11-19-2011, 09:13 PM   #9
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
extra make a small difference,tho buy a nrg kit is waste in my eye... simple audio amp wire wouldve be fine
MORE BACON STRIPS
negrosx13 is offline   Reply With Quote
Old 11-19-2011, 09:26 PM   #10
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Lol I was just watching the YouTube Hotwire mod..I'm not to sure if it really works..don't even think its worth my time ..hm..
S-Nation S13 is offline   Reply With Quote
Old 11-20-2011, 01:03 AM   #11
lude4life13
lude4life13 is an unknown quantity at this point
I really wish $10 would buy 1000 ft of that thick of gauge wire at home depo. I would be rich from doing battery relocations!!!!
lude4life13 is offline   Reply With Quote
Old 11-21-2011, 07:31 AM   #12
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
that ground kit looks terrible...and really tacky.
the ignition mod works fine, though. I did it to my hatch and it smoothed out the idle and helped with engine response noticeably. But all that means is that I had some crusty wiring, I would guess = /
nismoracingsx is offline   Reply With Quote
Old 11-21-2011, 08:14 AM   #13
Darren
Darren's Avatar
Darren is an unknown quantity at this point
Anyone that's ever been into Car Audio knows the value of good grounds, it's not about MAKING more power or sound, it's about KEEPING your power or sound...
A loose or corroded ground or grounds will stop your engine from functioning properly, thus LOOSING power.
Thus, the Ground Kit is NOT a waste of money, it's cheap insurance against a single ground becoming loose or corroded...
although, i do agree, it could have been implemented a little less tacky
Darren is offline   Reply With Quote
