Old 11-24-2011, 06:41 AM   #1
Croustibat
if you are not running more than 2 bar boost, you dont need one. Dont try to fix whats not broken.
Also, try to understand how and what a mod does before actually doing it.
Old 11-24-2011, 07:28 AM   #2
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Originally Posted by xteejaayx View Post
Hey guys,
A buddy of mine just gave me an Twin Power High Performance Ignition System from HKS; however, I'm not really sure how to install it. All it came with was the actual system and a wiring harness with three plugs and a grounding cable. If anyone has a picture of the set up on an sr20det, it would be much appreciated.
Thanks,
TJ
ground to chassis ground, one connector goto coil pack harness, second to where coil pack harness connects to the main harness. And I assume the third to the hks unit.
More than 2 bar, really? I doubt 90% of zilvia is running more than 29psi.
VNG704 is offline   Reply With Quote
hks, ignition, install, s14, sr20det
