Old 12-27-2011, 04:59 PM   #1
towlie
ill inspect the stock manifold for any sort of imperfections, and the turbo.
Was the gt30 top mount? does that make a difference in using a gasket or not?
Old 12-27-2011, 05:09 PM   #2
Kingtal0n
Kingtal0n's Avatar
The only thing I disagree with is the welded nuts theory. Are you poor fellows off your welded nut brains?
What happens when you need to take the turbocharger off- You packin' a grinder and some new studs and nuts in the trunk? Its not like a tattoo!
Old 12-27-2011, 05:12 PM   #3
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
If it's just a tack weld then you can still break the nut loose without any repercussions.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
