Old 01-31-2012, 05:34 PM   #1
jacobzking
jacobzking is an unknown quantity at this point
Removing KA checklist...
I know that most of this information is on here, at least in bits and pieces and what not, but I'm about to pull the KA out of my s14 and just want to make sure everything is unbolted and ready to go. I'll list what's unbolted, disconnected and tell me if I'm overlooking anything. Thanks in advance!
Driveshaft mount removed so the yoke can slide out easier
L & R engine mount top bolts removed
Radiator, fan shroud, fan, air intake all removed
Cat unbolted at down pipe
PS lines disconnected
Heater hose disconnected
ECU harness removed and pulled through firewall
Anything I'm overlooking?
Probably some ground wires that need to be undone?
Will the header come out with the car (clear the steering rack)?
Thanks guys! Its been about 5 years or more since I've pulled one of these... no, 7 years plus.
jacobzking is offline   Reply With Quote
Old 01-31-2012, 06:14 PM   #2
90240sx07
90240sx07 is an unknown quantity at this point
think the header will but not the down pipe should be 2-3 bolts to undo that and theres a couple of grounds on the firewall trans bolts or undo the trans x member and driveshaft and tranny harness if your pulling the trans with it
90240sx07 is offline   Reply With Quote
Old 01-31-2012, 06:19 PM   #3
jacobzking
will the down pipe how the steering rack, is that the issue?
Old 01-31-2012, 06:26 PM   #4
project-c2
project-c2 is an unknown quantity at this point
Throttle cables, fuel line and return line, engine harness, starter cable and alternator cables.
project-c2 is offline   Reply With Quote
Old 01-31-2012, 06:29 PM   #5
jacobzking
got the fuel lines already but completely forgot about throttle cable and starter cable. thanks mate!
Old 01-31-2012, 07:27 PM   #6
90240sx07
believe it was cuz of the steering rack and it hitting it if i remember right
Old 01-31-2012, 07:35 PM   #7
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
There is a DVD that teaches you absolutely everything. Josh makes DVD's also telling you how to rebuild engines too. Anyone with an SR or KA should buy all of his DVD's. They are a must have, with the FSM (that you can also DL off his site)
I would make a copy and share with people if it wasnt for he's a good guy, with a couple kids to feed! He's a good man.
www.240SXTECHDVDS.org S13 KA24DE Removal DVD
KA-T ORG-Function over Flush
Walperstyle is offline   Reply With Quote
Old 02-01-2012, 09:19 AM   #8
project-c2
np. If equipped with A/C, I would unbolt the compressor from the engine, so you don't have to open the refridgerant lines.
Old 03-11-2012, 04:06 AM   #9
240 dream
240 dream's Avatar
240 dream is an unknown quantity at this point
im about to do the same thing do to a possible timing jump and possible cracked cylinder wall so i definatly need the same info haha
240 dream is offline   Reply With Quote
