Old 02-09-2012, 01:34 PM   #1
SMM
Trader Rating: (26)
SMM is an unknown quantity at this point
Feedback Score: 26 reviews
KA24DE Head filling with oil
Long story short. Compression is fine across every cylinder. Tops of pistons are clean (can even see .50 or whatever it says), spark plugs look fine. Car runs as if brand new.
Replaced valve stem seals while I was doing timing chain. Now car is smoking like crazy, gets worse when it reaches operating temperature. Small drops of oil coming out of exhaust.
I noticed the head keeps filling with oil, reference puddles next to shims in the pockets of the head, fills up on top of shims. Assuming oil is leaking down causing it to smoke.
No idea why it is doing this. Any ideas?
SMM is offline   Reply With Quote
Old 02-09-2012, 04:02 PM   #2
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
Are the new valve stem seals properly seated? I'd just have a machine shop do them just because of the margin of error.
slothonaleash is offline   Reply With Quote
Old 02-09-2012, 04:35 PM   #3
SMM
Trader Rating: (26)
Yes they were installed correctly.
Old 02-09-2012, 09:25 PM   #4
SMM
Trader Rating: (26)
More pictures.:
Old 02-09-2012, 10:39 PM   #5
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
that is normal. oil is supposed to be there to keep everything lubricated. i would check the seals again.
rcdad123 is offline   Reply With Quote
Old 02-09-2012, 11:07 PM   #6
SMM
Trader Rating: (26)
^ I have opened up many KA's and never seen that much oil. Yes some, but that is pushing the limit. In my opinion that is a bit excessive.
Intake side is pretty clean.
Side note: Took off valve cover. Cleared that oil out. Put it all together and started the car. It took awhile before it started smoking again, basically until it reached operating temp. I assume it only starts smoking once all that oil piles up.
I guess tomorrow I am going to take everything back off and check each seal.
