Old 02-10-2012, 03:36 PM   #1
boostfreak27
boostfreak27 is an unknown quantity at this point
Originally Posted by codyace View Post
Interesting placement with the external gate on the pre flanged ATP housing, at least we all know now definitivly that it will not fit without some well placed fabrication. I'm curious as to how to how close it is the steering shaft.
Personally, I'm still a fan of how we have JPC put them atop the manifold (which we'll be doing a different setup with the 2 bolt flanged turbos soon) as the MVS is no where near the BMC that way, and out of the way of everything.
COol stuff though. When are your planned power pulls? My entire turbo setup is off my car, and dare I say, awaiting your results to see which way I go.
However if you're far out, I'll probably just follow through my gut and get one too...I'm hoping to have it back on the dyno by mid march if I do go through with it
If everything goes as planned I am hoping to have it on a dyno by the end of next week. Also, are you speaking of the stock cast manifold that they are attaching the wastegate to? If so do you know the process they are using to attach? I just welded one up for an rb motor, and used a stainless tube on the top of the mani. It was my first time working with cast but it seemed to work well. I do know that cast isnt the easiest to attach a disssimilar metal to, and if not done with the right material can can lead to cracks. I used 99ni rod to weld it up. Just looking for more info on working with these materials, thanks.
boostfreak27 is offline   Reply With Quote
Old 02-11-2012, 08:36 AM   #2
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I personally do not know the rod or settings Jay uses with that stuff, I end up helping afterhours with installations and mock up stuff. He's the welder, and while I should know more (as it's in my personality) it's usually so hectic that I don't have time to ask the questions as we're getting cars in and out, or setting up equipment)
I can ask him though, and send you a PM.
Also, anxiously awaiting your dyno work. Did you previously dyno the car with a 2871?
gt2871, gtx, gtx2867r
