Old 02-10-2012, 08:04 PM   #1
PureRush
PureRush is an unknown quantity at this point
Newly turbo'd KA wont start HELP!!!! w/ Vid
I just installed my turbo on my KA and I go to start it and the engine wont start. It cranks for a little bit then seems to die out and then I hear a small pop and the RPM needle jumps. I charged the battery and used a battery from my other car and the same thing happens. Heres a video of it:
240sx Starter problem - YouTube
***PROBLEM WAS A BAD ECU
PureRush is offline   Reply With Quote
Old 02-10-2012, 11:13 PM   #2
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
sounds like the battery is dead.
rcdad123 is offline   Reply With Quote
Old 02-11-2012, 10:19 AM   #3
Corey121
Corey121 is an unknown quantity at this point
Check the grounds and evrything to the starter , i would say it is starter related if it was the battery it would click multiple times. When turbo charging that car you didnt have to do anythig that would make it not start so i guess the starter might be shot.
Corey121 is offline   Reply With Quote
Old 02-11-2012, 12:23 PM   #4
PureRush
Yeah well as I stated in the op I used two batteries, one which is in my other car and works perfectly fine
Old 02-11-2012, 12:45 PM   #5
waxball88
waxball88 is an unknown quantity at this point
Make sure you have the dizzy stabbed right. Even if you think it is, it probably isn't. Had to stab mine several times.
waxball88 is offline   Reply With Quote
Old 02-11-2012, 12:58 PM   #6
brizanden
brizanden's Avatar
brizanden is an unknown quantity at this point
Send a message via AIM to brizanden
i dont think thats starter. as stated check grounds when i swapped in a new ka setup exactly the same as when my car worked it wouldnt start either. I had to take off all my grounds sand em down again on the chassis and eyelet off the wire to get it to fire up.
brizanden is offline   Reply With Quote
Old 02-11-2012, 02:20 PM   #7
PureRush
Where are all the grounds located?
Old 02-11-2012, 09:11 PM   #8
freeagent3117
freeagent3117's Avatar
freeagent3117 is an unknown quantity at this point
put the sun visor down
freeagent3117 is offline   Reply With Quote
Old 02-12-2012, 06:47 PM   #9
PureRush
Ur so helpful!
Old 02-13-2012, 04:32 PM   #10
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
just saw the video link before i read this comment. after i saw the link i was cracking up at work
tapdeznutz is offline   Reply With Quote
Old 02-13-2012, 09:23 PM   #11
c_mancuyas8
c_mancuyas8's Avatar
c_mancuyas8 is an unknown quantity at this point
Just out of curiousity did you remember to plug the ign coil back up?
c_mancuyas8 is offline   Reply With Quote
Old 02-13-2012, 09:45 PM   #12
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
check all of your wiring. Sounds like your not getting enough power to the starter.
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 02-14-2012, 02:11 AM   #13
PureRush
Yes we got it to crank without dying cause it was being weird when we used jumper cables. Took off the cold side intercooler piping and hooked up the battery directly and it would crank fine. My friend and I checked to see if there was electricity going to the spark plug and there wasnt. We think its a bad coil so I'm picking one up on friday and cranking that bish up! That little thing is like $180 for oem and $80 for another brand, damn!
Old 02-14-2012, 02:26 AM   #14
c_mancuyas8
Use msd blaster cheaper than both
Old 02-14-2012, 02:33 AM   #15
PureRush
What do you mean?
Old 02-14-2012, 03:19 AM   #16
c_mancuyas8
Msd blaster coil thats what im using, well that and I did the ignition rewire. You can find that on kat.org there's guys on that setup running 500hp
