Old 02-21-2012, 04:04 AM   #1
riptor
riptor is an unknown quantity at this point
hey bro...what gauge wire are you using between the relay and the batt? what brand of fans are you using? what size fuse? what is the relay rated at?
def sounds like u might have too small wire...draw really isnt to much. melting means too much heat.
riptor is offline   Reply With Quote
Old 02-22-2012, 02:58 AM   #2
keMz
keMz is an unknown quantity at this point
ran 4 gauge batt wire from alternator to battery
running 2x 8 gauge speaker wire running the relay to the fuse (1 relay per fan) then 4ga running to the battery
flex-a-lite 210's then swapped um out with flex-a-lite 220s
both go into 1 fuse which is 40a. and the relays are 30/40a DEI relays.
Any ideas is helping me...
keMz is offline   Reply With Quote
