Off Topic Chat All non related chat goes here. |
02-17-2012, 01:28 AM | #31 |
I'm on my iPhone, too lazy to quote n delete other posts,
I'll be using front n rear speakers with tweeters. my front pillars has stereo cover for them.
straights are for fast cars, corners are for fast drivers. |
02-17-2012, 07:27 AM | #32 | |
Was just thinking there was some kind of check on a P/N switch and that would cause the issue. Though in the 5spd swap the main P/N switch under the hood is jumped.
'11 M56S '12 QX56 (wife's) |
02-17-2012, 09:24 AM | #33 |
My car seems to not run as efficient when I'm playing music, the set-up includes the CarPC and Subs as we have previously spoke about. I'm running the stock SR alternator at the moment. [My second one..I think I fried the first one cause I heard a weird noise then my dash light went on and the car died once the battery died.]
Would upgrading to the 125AMP Quest alternator really help the situation in power draw and such? Would the 75AMP alt fuse have to be upgraded to properly run a higher amp alternator? How much role does a battery play in this situation? I'm currently running the stock s13 battery branded by Exide. Would running anything like an Optima help in power performance? I don't have interest in running a capacitor. |
02-17-2012, 03:51 PM | #34 |
chargespeed
[QUOTE=Broadfield;4525609]I'm not sure what calipers you are talking about?
I have this stuff brand new: http://zilvia.net/f/sale-items/42634...em-nissan.html I have two S15 6-speed transmissions I have a brand new Chargespeed S13 coupe kit minus the front 20mm fenders that I acquired from a friend:
how much are u asking? |
02-17-2012, 04:07 PM | #35 |
First: Broadfield: massive props for supporting the community. I have 2 questions:
Is there not an aftermarket fiberglass subwoofer enclosure made for a standard spare tire well (that would fit in an S13 hatch)? I can't believe that someone other than JL doesn't make a decent fiberglass enclosure. I can pay someone to custom build one but it seems like a waste, since this is such a common thing to do. Second: This is a dual purpose daily/track car that I have tried to shave weight as much as possible. I do want to have a stereo though. What is the best performing light weight subwoofer on the market, in, say a 12" size? It's probably going to be a neodymium driver. I am already using Class D amps to cut down on weight, and plan on using the Morel Maximo components up front. Thanks! |
02-17-2012, 06:12 PM | #36 |
What would be a good single din head unit that is capable of blue tooth stream of music from my phone?
90 hatch-first s13- first failed project 96 zenki, hid retro fit- ls1 2013 |
02-17-2012, 07:09 PM | #37 | |||||
Trader Rating: (163)
Feedback Score: 163 reviews
If the piece you want to finish just has swirl marks on it then you can clean as above, then then scuff it with a grey scuff pad. Then simply paint it with the SEM paint. Quote:
How much am I asking for what? You quoted everything?! And which calipers are you talking about? Quote:
I'm not aware of any quality subs that are light weight. But there are so many brands out there these days that there is no way I can keep track of all of them. If you buy like a JL Audio WX, W0 or W1, they are pretty light just for the fact that they are entry level subwoofers... or any brand of entry level sub. The enclosure itself will be FAR heavier than the sub... the weight of the sub is the least of your concerns. Just remove the enclosure on track days!?! |
02-18-2012, 09:34 AM | #39 |
What GPS tracking system would you best recommend for my S14? I'm not looking to spend much (Over $200) but would like to purchase one some time in the future. Florida S chassis are thieve's new hotcakes.
02-18-2012, 02:51 PM | #40 |
I hate having a "stereo" system in my car. I just want a minimal unit to play back via AUX cable. Half din would be cool, or something I could route elsewhere and be out of sight. Suggestions?
02-18-2012, 03:38 PM | #42 |
I spilled some Pepsi on my radio and now one of the buttons sticks. (07 350Z OEM radio)
Is there anything you'd recommend to "fix" it without have to rip the whole thing apart? I read rubbing alcohol online because it dissolves quick but ill take your advice first over something I read online. |
02-18-2012, 04:50 PM | #43 | |||
Yeah, I'm using the 20mm fenders from the kit. Quote:
02-20-2012, 12:06 AM | #44 | |
02-20-2012, 12:41 AM | #45 |
Can you go over the step by step process of preparing the exterior body for paint? I would like to take my time and do all the body prep work myself. And when I'm content with my work, I will take it somewhere that can professionally paint it for me. A list of all the supplies and products that are needed would be most helpful. Thanks in advance!
02-20-2012, 01:45 AM | #46 |
do you have any recommendations on how to restore torn vinyl?
on my s13 door, the lining of the vinyl where the main cloth piece is has torn a bit. i want to take off the cloth and just leave it black but in doing that, the torn part will definitely be visible..
FS: Nismo R-Tune Camshafts for VQ35DE. |
02-20-2012, 09:43 AM | #47 | |
Thanks for the offer, but I'm going to try a few avenues first. Hope to find someone local that installs them to do a little side work.
02-20-2012, 11:11 PM | #48 |
Is the Stock fuel sender able to be calibrated or anything? Ever since I installed a fuel tank into my hatch the first half of the tank goes like water, then the 2nd half takes awhile to get to "E" [On my gauge] Could this be fuel sender related?
02-21-2012, 12:36 AM | #49 |
Trader Rating: (71)
Feedback Score: 71 reviews
this questions goes with painting plastic interior pieces.
are you using anykind of adhesion promoter on plastic interior pieces like the s13 cluster bezel? or just scuff and bomb with sem color coat? whats that black glue your using on the s13 bezel? thanks a bunch! |
02-21-2012, 08:08 PM | #50 |
Taken from CamryOnBronze's thread...
Are you Doing anything different on an S14 door panel than what you have done on the S13 doors? I am not sure if I should try to peel the cloth off or go over it with new material since the S14 isn't concave. Since you have 3 degrees, have you ever thought about pursuing anything full-time with any of them? I'm always looking for talent at our factory in MS. You'd be an interesting talent to have around.
http://www.youtube.com/canaanmanley |
02-21-2012, 08:58 PM | #51 | |||||||
"Seam sealer is basically the last thing you do before base coat. Since a lot of people seem to be asking, in simplistic terms, it breaks down like this:
NOTE: I did not list ultra specifics like wiping down the bay with a cleaner before the main primer etc. Or proper sanding techniques and so on. Complete books are written on this type of thing, so I'm obviously not getting too detailed in this post. If you have any questions please let me know. My bay turned out phenomenal so I know these techniques are up to my standards. The bay will obviously need to be wiped down and tack ragged before the final paint also. So there are a lot of little things besides what I listed. But if you are having a body shop do the final paint work then they will take care of this." Quote:
As for my degrees, I went to school to become an engineer. However, I realized that any sort of desk job might not challenge me in the way I like to be challenged. So I stuck with what I love... car audio. Low and behold I'm making clusters and whatnot now, in addition to the audio stuff I have always done. Why, do you have a janitor job open for me or something? But in all seriousness, I appreciate the offer. I actually saved your PM from Nico about it just in case I need/want a career change in the future. Out of curiosity, what type of position would you want me to fill? |
02-21-2012, 10:57 PM | #53 | |
Stinger SAS Car Audio Vinyl / Carpet Install Spray Adhesive For concave, high heat, ultra strong bond I use a contact adhesive out of a spray gun. I use DAP Welwood Landau Top Adhesive: 1 Gal. DAP Weldwood HHR Contact Cement I use an automotive grade spray gun with a 2.0 tip. This glue is the only thing that will hold year after year on the door card. |
02-22-2012, 06:40 AM | #54 | |
02-22-2012, 08:57 PM | #55 |
My apology if this has been covered,
Have you ever dealt with having a car shipped to you for work? If you don't mind p.m'ing me a price to do your cluster setup (same as the one on your car) along with setting up a fully functional jdm climate control unit from scratch. If you can add what parts I'd need to complete that conversion it'd really help in the quest of piecing that together on my end.
www.tm-spl.com Kouki's & some apple juice. |
02-23-2012, 05:39 PM | #56 |
My car vibrates in the rear when I take off. Roughest when taking off and turning. Not too bad when taking off not turning. Does better if you drop the clutch a bit rather than easing out. Just changed the diff fluid and it's better but not great.
Driveshaft? Bushings/mounts? New differential?
For all the world knows, my vagina could be moist with desire as we speak. |
02-23-2012, 06:00 PM | #57 |
i know we talked about this earlier on the other thread but could you recommend me somethign for the near future... i dont really use any headunit like cd or radio on my build car, you said to just run a amplifier and speakers... what amp and speakers do you recommend for all around quality and a good price. doesnt have to be high class sounding since im not building a sound system, ill leave that for my daily vert...
and ps. im still frying my brain thinking about what to do with the gauges, i can't seem to make up my mind to what i want to ask for an exact price... |
02-23-2012, 07:01 PM | #58 |
Ok I have two questions for you.
Speaker question: I plan on putting an Alpine iDA-X305S in my S13 and maybe even into my STi as well. I have a 04 Chevy Avalanche with the factory Bose system in it and honestly have never heard a clearer, more well balanced setup. Whether low, or as loud as possible the sound is completely clear across all levels no matter what style of music you're listening to. With the Alpine, what speaker combination would you recommend to achieve a sound similar to this in either of my cars? I would prefer to do it without subs/amps as both cars are more on the track/performance side and would prefer not to add them. Would it be possible to have the sound without them simply with speakers/tweeters? Ideas/advice? Second question is an interior question: I plan on making a hidden setup for my S13's double din pocket to cover up my headunit/gauges so that the lights don't bother me at night. Do you have any idea where to get a generic flip up hinge such as that in a 350z's pop up compartment, the STi coin tray, anything like that where it's a simple push and it opens, and push down and it's closed. Thanks. |
02-23-2012, 09:43 PM | #59 |
I read through this Thread and did not see the answer to my question. So I will ask it.
What de-pinning tools do you use/recommend ? I would like to try my hand at cleaning up my wiring harness and want to do a proper job that looks neat and tidy with proper plugs. Thanks in Advance!! Dustin Z |
02-23-2012, 11:09 PM | #60 |
Toby, does Viper make a sensor or switch for the gas door? So that if an intruder opens the gas flap (while alarm is armed), it will trigger. I know I could get creative and try to customize one, but was wondering if Viper offers any such device.
And if they do make it, is it compatible with the Viper 5901?
Tags |
broadfield, toby |
