Old 02-26-2012, 11:44 PM   #1
since87
since87 is an unknown quantity at this point
why wont my s14 start..but starts when jump started?????
so my s14 wont start unless jump started.......
and after i turn off the car...and try start it, it wont unless i jump start it again...
so stumped...help please!!!
and i replaced the battery with a rep top optima....fyi
since87 is offline   Reply With Quote
Old 02-26-2012, 11:46 PM   #2
Tarrbaby
Tarrbaby is an unknown quantity at this point
have you tested your alternator?
Tarrbaby is offline   Reply With Quote
Old 02-27-2012, 12:05 AM   #3
since87
i havnent......what symptoms would indicate the alternator being the problem?
Old 02-27-2012, 12:26 AM   #4
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Get a multimeter and see what voltage you're seeing across the battery with the car running and off. If you have less than 9v across the battery when you're trying to crank it, it wont start. Once you jump it and its running, check it again. If you're not seeing atleast 13v, then your alternator is not doing its job.
CLICK HERE!!!
Old 02-27-2012, 12:07 PM   #5
turbo please
turbo please's Avatar
turbo please is an unknown quantity at this point
More then likely it's the alternator. Mine randomly died at a red light and started right up after a quick jump. I Tested it how fliprayzin240sx described above. If it's running and your battery isn't reading above 12v then your alternator is not doing it's job
turbo please is offline   Reply With Quote
Old 02-27-2012, 12:16 PM   #6
ryandriftingfat
ryandriftingfat is an unknown quantity at this point
My buddy has an S13 SR that would run and start fine when it was hooked up to my truck. It would idle fine on it's own but you try to move it and it would sputter and die.
Turns out his grounds weren't attached right.
ryandriftingfat is offline   Reply With Quote
Old 02-27-2012, 03:22 PM   #7
562s13
562s13 is an unknown quantity at this point
i was just about to say that. check your grounds first. that happened to me as well
"My car got into a fight with a 18 wheeler, and the truck won."
562s13 is offline   Reply With Quote
Old 02-29-2012, 10:33 AM   #8
tapdeznutz
tapdeznutz's Avatar
Trader Rating: (50)
tapdeznutz is an unknown quantity at this point
Feedback Score: 50 reviews
i agree with everyone...easiest way to test for alt is multimeter across pos and neg of battery...should show around 14v as i did mine a few days ago when i was doing the coil direct to battery mod.
tapdeznutz is offline   Reply With Quote
