Old 03-06-2012, 02:14 PM   #1
ultimateirving
ultimateirving's Avatar
Originally Posted by 90pearlz View Post
Word, low boost and walbro shouldnt max out the injectors, but pretty sure T28 deserves a different MAF, Im just trying to help a brotha out. Interested to know what the problem is...OP is using a SOHC MAF I'd say that's no good and he should try to get that Z32 set up properly. Disconnect that SAFC and see what happens, maybe its as easy as that.
i know what you mean. Sohc maf can be used with s13sr if wire properly, safc should not be needed at all for his set up and likely could cause more issues.
Z32 with lq4 swap
