Old 03-07-2012, 10:53 AM   #17
axiomatik
axiomatik's Avatar
Originally Posted by Blues13 View Post
Please explain why it would not be injector #4 if he swaps that injector to cyl 3 and the problem follows to that cyl? Obviously, if cyl 4 still has the problem after swapping, than he can start checking the ignition/coilpacks. Best to check one system at a time.
He is replying to the OP's question, not your post. Indeed, if you swap injectors and the problem follows the injector, then the injector is the problem. Ohming out the injector isn't reliable a reliable test. When one of my injectors died, the bad one ohmed out fine, but it was stuck open.
