![]() Join Date: Jan 2007
Suspension Geometry Questions
Hey guys,
I have an S13 with a VQ35 swapped into it. I currently have the motor out of the car, and I'm trying to troubleshoot a few fitment issues. I'm using McKinney mounts, which fit and function great, but the VQ is a very tall motor, and I currently won't be able to fit a hood. I already got spacers for the hood, but I still don't think it will quite be enough. So, I was considering making 1/2 inch spacers for the front cross member to lower it a bit, effectively lowering the motor. My only question is if this will screw up the suspension geometry a ton, or if the effect will be nominal. I do have FULLY adjustable suspension, including the front LCA's, so I'm thinking I could be able to compensate for it? Ideas please, and preferably only constructive (or informed) ones. Thanks guys. Here's a photo of where the engine was sitting: ![]() |
![]() Join Date: Nov 2005
Lowering your crossmember will lower your roll center height, which is generally bad. You can compensate with longer ball joint shanks or knuckles that compensate by moving the ball joint down.
Either way, it's probably better to run hood spacers or a custom hood.
