![]() Join Date: May 2009
![]() Feedback Score: 8 reviews
![]() I took my car to get smogged and it failed miserably.
Here's what it read... Car: 1990 stock KA24e 240sx 15mph: HC max: 85 , measured: 101 CO max: .54 , measured: .75 NO max: 565 , measured: 655 25mph HC max: 67 , measured: 104 CO max: .45 , measured: 1.43 NO max: 522 , measured: 690 So those were the numbers, can anyone point me in the right direction just by reading that? Any and all help is appreciated. |
That wasn't a miserable fail haha.
What's the condition of the catalytic converter? Are there any leaks in your exhaust system? Any aftermarket exhaust components or engine modifications. Any check engine light codes? When did you smog it last? Did it pass then? Do you know the numbers for that run as well?
![]() Join Date: Oct 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Yeah those numbers are not that bad, Mine where crazy high that they put the sniffer on and right away the guy told me NOPE!!!! that he wouldnt even take the car in
smogged my single cam and it barely passed but it had 260K on it and the original cat and exhaust. i just made sure i changed my filter, oil, my plugs, cap and rotor and it seemed to help it pass. still a weak cat tho
1989 stock KA24E S13
15mph: HC max: 83 , measured: 83 CO max: .53 , measured: .27 NO max: 559 , measured: 231 25mph HC max: 65 , measured: 65 CO max: .44 , measured: 30 NO max: 516 , measured: 435 |
#6 | |
I would suggest fixing the leak at the cat and also make sure you have the heat shield on the exhaust manifold and the mid pipe going to the cat (Mid pipe heat shield has a fiberglass insulation in the middle). The heat has to be contained all the way to the catalytic converter for the converter to do it's job properly. That's why the heat shields were there in the first place as well. That helped me pass with no problems. I had a worst failure, went to smog 4 times before it actually passed.
![]() Join Date: Mar 2004
Illegal smog is not going to work in California for much longer...
We need to just get the cars to pass correctly now... If there is no CEL and all leaks are fixed, I would consider changing the catalytic converter and spark plugs for a total of about $150... And try testing again... I'm pretty sure that it will be enough... In California this year, they have added more restrictions to get older cars off the road... It's getting more and more strict...
http://respectvolkracing.blogspot.com/ |
![]() Join Date: Jun 2010
Trader Rating: (32)
![]() Feedback Score: 32 reviews
^ I beg to differ.. If I'm waving $250+ in front of some smog dude's face, I'll be hard pressed to think he won't do anything but guarantee to pass me regardless of what bureaucratic bullshit is going on with the California BAR or EPA.. Money speaks and some things are just worth the calculated risk..
![]() Feedback Score: 20 reviews
i dont think your sposta tell people to break the law on here.
Plus if its stock it should pass anyway, try seafoam, it helps clean out the egr and iacv unless you want to pull them off and actually clean them. Are you sure there's actually a cat in there? i see alot of hollowed out ones.. maybe clean the 02, make sure its super hot before you test it. i had to get a new cat for mine back when it was stock and it passed best of luck man! |
Trader Rating: (32)
lol I believe we're all breaking the LAW in one way or another, driving modified 240's on a daily basis. Being low is technically illegal, but no one's fussing around in the "how to make your car scraping low" threads
![]() But yeah smog stuff is kinda iffy or what not, so that conversation ends here. ![]() |
