Old 03-18-2012, 06:35 PM   #1
mmccall72
mmccall72's Avatar
mmccall72 is an unknown quantity at this point
No crank no start after trans swap, need help
S14 was an auto, ran and drove fine, swapped to five speed. Started it up and drove around the parking lot a bit then pulled back in. Went to start it up again and the 30A ignition fuse popped, replaced it and it popped again. I've been checking fuses, connections, and grounds, and have been repairing any damage in the wiring harness that I've come across. In the process the ignition fuse doesn't blow anymore, but I'm dealing with a no crank no start now that I haven't been able figure out. Any suggestions?
mmccall72 is offline   Reply With Quote
Old 03-18-2012, 06:52 PM   #2
andyv316
andyv316 is an unknown quantity at this point
check the wires going across the front of the engine. Mine did that back in the day and the was a wire that got rubbed in two.
andyv316 is offline   Reply With Quote
Old 03-18-2012, 08:55 PM   #3
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
check starter wires.
rcdad123 is offline   Reply With Quote
Old 03-18-2012, 09:02 PM   #4
supakat
supakat is an unknown quantity at this point
I believe you need to jump a wire to make the car think it is in Park to turn on since it was an Auto.
12.96 @ 116.36 - Build Thread
supakat is offline   Reply With Quote
Old 03-18-2012, 09:21 PM   #5
mmccall72
mmccall72's Avatar
already took care of the p/n safety switch. not getting power to the starter, fuse is not blown.
Old 03-18-2012, 09:32 PM   #6
supakat
Just to confirm, power or starter signal power?
Old 03-18-2012, 11:21 PM   #7
mmccall72
mmccall72's Avatar
no power at starter signal fuse
Old 03-18-2012, 11:27 PM   #8
silver350z05rb
silver350z05rb is an unknown quantity at this point
mhhhm water was once leaking on my starter from the lines, kept blowing the Big 100amp fuse on my s14,hope that helps somehow
silver350z05rb is offline   Reply With Quote
Old 03-19-2012, 05:59 AM   #9
supakat
Starter signal line will not have constant power. If it did, then the starter would always be engaging. While testing the signal, have someone turn the ignition key and it should light up. It may be possible that the starter relay is faulty. Have you tried jumping the starter signal on the starter to confirm it is not sticking or inhibitor switch is faulty?
Old 03-19-2012, 08:02 AM   #10
mmccall72
mmccall72's Avatar
Tried jumping it yesterday and its not sticking, The inhibitor switch is part of the auto trans so its not there, but doesnt the clutch safety switch take place of that with the m/t? I'll be checking it after class today
Old 03-19-2012, 08:23 AM   #11
supakat
I meant to say the actuator on the starter. Not sure if the wiring is the same but same concept. The ignition barrel might be dirty.
