Old 06-24-2009, 04:30 PM   #1
Asmar
Asmar's Avatar
Asmar is an unknown quantity at this point
s14 S14 Fujita Short Ram Air Intake
I was wondering if anyone had pics of the Fujita short ram air intake installed on their S14? Searched around but didn't find any pics. Was just curious to see how it looks like installed, seems like it would look pretty clean.
Asmar is offline   Reply With Quote
Old 06-24-2009, 09:31 PM   #2
codunc
codunc's Avatar
codunc is making a name for him/her selfcodunc is making a name for him/her self
looks like every other intake to me.. nothing special
codunc is offline   Reply With Quote
Old 06-24-2009, 09:37 PM   #3
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
I'm digging the heat shield. CARB # available?
Pacman is offline   Reply With Quote
Old 06-24-2009, 09:58 PM   #4
Tensor187x
Tensor187x has a little shameless behavior in the past
I agree...
Tensor187x is offline   Reply With Quote
Old 06-24-2009, 10:03 PM   #5
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
the only thing I would buy from them would be there filter other than that pipeing is pipeing nothing special
s13 @ fullboost is offline   Reply With Quote
Old 03-30-2012, 11:46 PM   #6
loremzalizares
loremzalizares is an unknown quantity at this point
whats the difference between ram air intake and cold air intake? im just confused because when i search for ram air intake its always cold air intake will be the result.thanks
loremzalizares is offline   Reply With Quote
Old 03-31-2012, 12:07 AM   #7
90S13hatch_tony
90S13hatch_tony's Avatar
Trader Rating: (24)
90S13hatch_tony is an unknown quantity at this point
Feedback Score: 24 reviews
Ram intakes are usually shorter and also called "WAI" (WARM AIR INTAKES) Because the suck in warm air instead of cold sometimes giving you better MPG since there isn't enough cold air to produce a better combustion cycle that causing better power
90S13hatch_tony is offline   Reply With Quote
Old 03-31-2012, 12:48 AM   #8
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
Please look up the definition of ram before you start telling people what it is if you don't know yourself.
I know your lazy so I'll do it for you.
ram= Roughly force (something) into place. Is it short air intake to you??
To force air into engine is to have a ram intake
Ram Rod Tunnel Ram Intake Photo 2
The best thing you can do is, throw that battery in the trunk and buy 2 couplers and a pipe for $40 and any filter you want. Cut a hole where the battery went and throw the filter below the battery. Any aluminum intake pipe for a 240, is horrible unless its insulated from the radiator. Radiator is throwing off heat radiation. Plastic fan shroud will help, but it still needs to get wrapped.
Hashiriya415 is offline   Reply With Quote
Old 03-31-2012, 12:48 AM   #9
migzs14
migzs14 is an unknown quantity at this point
dam this thread is old, but yea he's ^ right. I made a heat shield for it similar to that one and I got a slight power increase than before. pm me if you want pics
migzs14 is offline   Reply With Quote
Old 03-31-2012, 01:08 AM   #10
90S13hatch_tony
Trader Rating: (24)
You must know the word RAM from experience since you think you know all there is to know about "ramming" things into its place.
And if you read correctly i never gave a definition of what "ram" really is.. i simply explained the difference between cold and warm intakes....maybe i should of made my lettering BIGGER SO ITS EASIER TO READ.
Old 03-31-2012, 01:17 AM   #11
murda-c
murda-c's Avatar
lmao...you definitely said that they were called warm air intakes and sucked in warm air...which is exactly the opposite of reality.
240sx, kouki, nissan, silvia, zenki
