Old 04-14-2012, 12:44 PM   #1
Yuda
Yuda is an unknown quantity at this point
240sx brake booster differences
As far as I know the two different brake boosters are the one for the 240sx with ABS and the one without ABS. But I've also read that there is a difference between the auto trans and manual trans.
So my question is are there any other brake boosters besides those two and is the one that is used for the ABS models the same use for the auto trans models.
Yuda is offline   Reply With Quote
Old 04-14-2012, 12:51 PM   #2
RandallSharp
RandallSharp's Avatar
RandallSharp is an unknown quantity at this point
Best way to tell is to go to a site like autozone or o'reilly, search up the different parts using the different variables and check the part numbers. For instance, if the booster for ABS and the one for non-ABS have different numbers, they're different. Then say the booster for manual has the same number as the auto, it's the same. Only takes a few minutes and works with any part really.
1991 240sx Hatch Daily'd!
RandallSharp is offline   Reply With Quote
Old 04-16-2012, 10:38 AM   #3
cdlong
You could also check the FSM. You didn't mention what year you're looking at, but I'm pretty sure each model only has 2, manual and ABS/auto.
cdlong is offline   Reply With Quote
Old 04-16-2012, 05:30 PM   #4
Yuda
s13 240sx. yup i tried the looking at the auto parts store, i did advance, and rockauto, both showed only two for all models of the chassis through all the years of s13 ( i entered each year individually in the search as well as models) did not check fsm but ill try that. ill also give nissan a call and see what they come up with. thanks guys.
Old 04-16-2012, 05:39 PM   #5
jr_ss
Courtesyparts.com will be a good spot to check. Look under OEM parts. However, there are only two variations between all models. By that I mean, S13 has two, S14 has two, etc....
Old 04-16-2012, 08:50 PM   #6
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
S14 Non-ABS, manual transmission brake booster is the smallest brake booster of all the S-chassis boosters.
Old 05-10-2012, 06:46 PM   #7
ultramagnus
ultramagnus's Avatar
Trader Rating: (41)
ultramagnus is an unknown quantity at this point
Feedback Score: 41 reviews
yeah pretty old thread but only difference as i've just called the parts store is that on s13's they just ask for abs or non-abs. so either manual or auto will work fine as long as it's for the correct set-up.
"Consistency is Victory"
ultramagnus is offline   Reply With Quote
