transmission whining noise.....help
Need help figuring what's going on with my s14 transmission.... I get this whining noise when I put.into gear right when I'm about.to go ...... But once it gets going it.goes away and come back when I go into 2nd and so on..... I recently swap my transmission cause of that problem like.a week ago now its doing the same thing again ..... Anyone have the same issue.... Or knows what it might be... Any info would help
Which Tranny fluid did you use?
I know its not the throw out bearing..... Cause it only make that whining noise when i go in gear bout .to go.... But once it goes it drives normal
[QUOTE=wangan_cruiser;4621341]have you check the throw out bearing for any wear?[/QUOTE] |
Amsoil... AMSOIL - Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 (MTG)
or Redline... Red Line Synthetic Oil - Gear Oil for Manual Transmissions - MT-90 75W90 GL-4 Gear Oil
#10 | |
#15 |
![]() Join Date: Aug 2007
The reason that you need gl4 is because of the brass synchros our transmissions have. The additives in gl5 will eat these away and make them take a shit. If you have a tranny that runs good with gl5, just give it a couple months of some repeated hard use and you'll wish you had used gl4 from the beginning.
OP, you sound like you have a pilot bushing problem. It's the little bushing that goes between the end of your crank and the trans input shaft. Once it starts to go it makes a whine, and eventually it'll make a whine in all gears. Also you could check your tranny mount, if it's worn it could be stressing the pilot bushing/input shaft and causing the whine. |
#16 | |
#18 |
[QUOTE=Steinkrunk;4624282]The reason that you need gl4 is because of the brass synchros our transmissions have. The additives in gl5 will eat these away and make them take a shit. If you have a tranny that runs good with gl5, just give it a couple months of some repeated hard use and you'll wish you had used gl4 from the beginning.
OP, you sound like you have a pilot bushing problem. It's the little bushing that goes between the end of your crank and the trans input shaft. Once it starts to go it makes a whine, and eventually it'll make a whine in all gears. Also you could check your tranny mount, if it's worn it could be stressing the pilot bushing/input shaft and causing the whine.[/QUOTE i don`t intend to argue, but todays gl5 will not harm brass synchros or anything in the transmission for that matter. the factory rec. gl4 because back then there was no gl5. gl5 is a superior lubricant to gl4. gl5 has additives that gl4 does not have. you can use gl5 on any transmission that uses gl4, but you cannot use gl4 on a transmission that requires gl5. i wanted to make sure that i`m not sabotaging myself by using gl5, so i did some research and now i know i`m not. so there, gl5 will not damage our transmissions. you want to use something better, use full synthetic 75-90. it will shift smoother even when cold. AGAIN, i don`t want to argue, just researched to make sure i`m not wrong. ![]() |
#19 |
![]() Join Date: May 2011
You are wrong because the additives in gl5 are what cause the brass ( bear in mind the word BRASS ) syncro's to go to shit. Go ahead and put RP in your sr trans and go to a event maybe 2. Let's see how long your trans last before gears are gone/missing.
