Old 05-05-2012, 07:24 PM   #1
RED_P1LL
RED_P1LL is an unknown quantity at this point
Need help installing a NISMO thermostat in a red top sr.
Ok so I ordered a koto radiator and NISMO thermostat and I've searched but I cant find anything on installing the thermostat. Don't laugh too hard but any help would be great thanks!
RED_P1LL is offline   Reply With Quote
Old 05-05-2012, 07:30 PM   #2
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
HAHAHAHAHAHAHAHA oh wait, yeah I'm still laughing HAHAHAHAHAHAHAHAHAHA!
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 05-05-2012, 07:32 PM   #3
russian
russian's Avatar
russian is an unknown quantity at this point
Send a message via AIM to russian
1. uninstall sr.
I must break you.
russian is offline   Reply With Quote
Old 05-05-2012, 07:42 PM   #4
slydin240sx
slydin240sx is an unknown quantity at this point
Oh dear god.
slydin240sx is offline   Reply With Quote
Old 05-05-2012, 07:46 PM   #5
towlie
First you remove the transmission, in order to gain access to the steering shaft. Once you pull the steering assembly, go ahead and rip out the dash.. It all needs to come out. Only then can you drop the subframe, which in turn allows you to access the ONLY tstat port on the vehicle (in the gas tank)
It's really simple
Old 05-05-2012, 07:51 PM   #6
Grimace
Grimace is an unknown quantity at this point
Send a message via AIM to Grimace
It's really simple
Dont forget to drain the driveshaft fluid and remove the muffler bearings first!
Grimace is offline   Reply With Quote
Old 05-05-2012, 07:54 PM   #7
WV_SR20
WV_SR20's Avatar
WV_SR20 is an unknown quantity at this point
PM'd you out of kindness and pity, plus it means I get to be an asshole the rest of the month.
WV_SR20 is offline   Reply With Quote
Old 05-05-2012, 07:54 PM   #8
russian
russian's Avatar
muffler bearings? our cars use hyperdoofinator valve instead, you dumb redneck.
I must break you.
Old 05-05-2012, 07:59 PM   #9
97nismo
97nismo's Avatar
Trader Rating: (53)
97nismo is an unknown quantity at this point
Feedback Score: 53 reviews
redtops dont come with thermostat's....
if you change the headlight fluid it should work fine and stay cooler...
as for the koto radiator, i would exchange that for a koyo
Feedback:
http://zilvia.net/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
Old 05-05-2012, 09:40 PM   #10
Pinggg
Pinggg's Avatar
Trader Rating: (22)
Pinggg is an unknown quantity at this point
Feedback Score: 22 reviews
what is a thermostat?
Pinggg is offline   Reply With Quote
Old 05-05-2012, 09:59 PM   #11
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
remove the upper water neck, it is 3 bolts, i believe they're 10mm, the thermostat is located behind that.
SW Fab
shiftdrift is offline   Reply With Quote
Old 05-05-2012, 10:00 PM   #12
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
Thank you for your contributionClick here to view image in full size
omgRWDgoodness! is offline   Reply With Quote
Old 05-05-2012, 11:35 PM   #13
leung
leung's Avatar
Trader Rating: (73)
leung is an unknown quantity at this point
Feedback Score: 73 reviews
^ LOL
msglnth
leung is offline   Reply With Quote
Old 05-06-2012, 12:00 AM   #14
Enna
Wait, you were serious? HAHAHAHAHAHAHAHA
Ok honestly though, you need help.
Old 05-06-2012, 12:06 AM   #15
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Ugh. Enjoy this while you can.
The thermostat housing is on the front of the engine, attached to the lower radiator hose. It's attached by 3 nuts. Clean it well before you reassemble, and make sure when you install the new thermo, the little hole is up, it's a vent/bleeder thingy. Make sure that the thermo is seated completely in its groove before you tighten down the housing cover, otherwise it will bind and crack. Don't ask how I know. Make sure you bleed out your cooling system thorough afterwards.
Old 05-06-2012, 01:28 AM   #16
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
S-Nation S13 is offline   Reply With Quote
Old 05-06-2012, 03:31 AM   #17
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
if you cant even do that, you shouldnt work on your car at all, you should pay someone to do that :/
andisan is offline   Reply With Quote
Old 05-06-2012, 03:39 AM   #18
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
This is the best video I could find, cuz there is a girl in it, and that is why most of you will watch it.
http://www.youtube.com/watch?v=qcHiP_8nmpw
Hashiriya415 is offline   Reply With Quote
Old 05-06-2012, 09:33 AM   #19
russian
russian's Avatar
we all start somewhere. i know when i did replace mine like 10 years ago i looked in the manual to see how to do it. and yes, make sure the bleeder hole is up not down.
I must break you.
Old 05-06-2012, 10:23 AM   #20
Juantwo3
Juantwo3's Avatar
Juantwo3 is an unknown quantity at this point
everytime i get on a thread someone is always gettiing lit up like a christmas tree , its always a younginnn, and its always an old guy that has nothing better to do.
entertaining indeed.
Juantwo3 is offline   Reply With Quote
Old 05-06-2012, 10:31 AM   #21
russian
russian's Avatar
just go make me a sammich
I must break you.
Old 05-06-2012, 10:32 AM   #22
Brentbohn
Brentbohn's Avatar
Brentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choices
oh my who put your sr in?
Wanted: Good well mannered athletic woman with her own classic or sports car.... send photo of car
Brentbohn is offline   Reply With Quote
Old 05-07-2012, 06:30 PM   #23
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
I'm in Hampton...shoot me a PM if you need help with this...
CLICK HERE!!!
Old 05-08-2012, 07:23 AM   #24
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
i'm in the 757, may i see a picture of your car?
slow40sx is offline   Reply With Quote
Old 05-08-2012, 07:27 AM   #25
slow40sx
slow40sx's Avatar
fuck lol double post
Old 05-08-2012, 03:04 PM   #26
jdmspooge
jdmspooge's Avatar
Trader Rating: (39)
jdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura aboutjdmspooge has a spectacular aura about
Feedback Score: 39 reviews
Cmon guys leave him be. At some point we all needed some tech know-how help before right? Lock this thread! His question has been answered!
jdmspooge is offline   Reply With Quote
Old 05-08-2012, 03:45 PM   #27
tinys s14
tinys s14's Avatar
tinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-knowntinys s14 is making his/her stupidity well-known
The thermostat is behind the flux capacitor
tinys s14 is offline   Reply With Quote
Old 05-08-2012, 03:49 PM   #28
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Hoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really nice
Feedback Score: 25 reviews
RED_P1LL, before this gets locked, I highly suggest you download and praise the FSM here:
http://www.zfever.com/v1/View-docume...20DET-FSM.html
The phase2 link that you'll find in google no longer works. This is for the s14 SR but it pretty much the same.
Hoffman5982 is offline   Reply With Quote
Old 05-08-2012, 05:15 PM   #29
Om1kron
Om1kron's Avatar
Simone : My 1996 240sx: Replacing Thermostat and Timing Chain Tensioner
Wayne Edwards
https://om1kron.blogspot.com
Old 05-08-2012, 06:02 PM   #30
!Zar!
!Zar!'s Avatar
Use an OEM thermo.
