Old 05-15-2012, 10:34 AM   #1
BlueMissle sx
BlueMissle sx is an unknown quantity at this point
Cosmetic HeadGasket
Ok so a friend told me these gaskets didn't seal very well.
has anyone ever used one and what were the results leme know please
thanks
BlueMissle sx is offline   Reply With Quote
Old 05-15-2012, 10:46 AM   #2
s14k
s14k is an unknown quantity at this point
I use them on every build i do never had a problem yet.
s14k is offline   Reply With Quote
Old 05-15-2012, 10:47 AM   #3
BlueMissle sx
Nice were the head and block decked?
just curious
Old 05-15-2012, 11:27 AM   #4
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
just curious
Thats actually the requirement if you want it to seal properly.
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 05-15-2012, 11:48 AM   #5
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
like he said. metal headgasket wont forgive any perfections from the surface. it is adviceable to get the surface milled have a flat surface. if you want it to seal properly you can try to use a copper spray gasket maker and decked it.
Old 05-15-2012, 12:07 PM   #6
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
It is for cosmetic purposes only.
Old 05-15-2012, 12:24 PM   #7
DrIvEsldEwAyS
DrIvEsldEwAyS is an unknown quantity at this point
never had a problem with the 2 ive used.
-1990 240sx hatch sr20det- gt35r, blah blah blah
DrIvEsldEwAyS is offline   Reply With Quote
Old 05-16-2012, 09:22 AM   #8
BlueMissle sx
Alright thanks guys im gonna check the surface of the head and block..
Not wanting to pull the block just to resurface it, how well does this copper spray seal?
I had a metal head gasket on before replacing because i read shit numbers on compression test.. cyl#1 30.. the other 3 150 just gonna switch gaskets and see if it fixes my problem
Old 05-16-2012, 09:48 AM   #9
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
I've had 2 cosworths..never resurfaced block, just the head. No problems. (Using copper spray) I actully reused one in my motor and later ended up making 400whp..of course I don't own the car anymore so don't know how the motor is doing.
R@ddy is offline   Reply With Quote
Old 05-16-2012, 09:52 AM   #10
BlueMissle sx
Nice Ive herd good things about cosmetic.. of course after i order a cosmetic..
do you know any difference in the two gaskets like what would make one better than the other
Old 05-16-2012, 09:54 AM   #11
Vadim's13
Vadim's13's Avatar
Vadim's13 is an unknown quantity at this point
Haha coSmetic
BTW I don't really care what others may say but u HAVE TO deck ur head if u had any problems with HG...
Vadim's13 is offline   Reply With Quote
Old 05-16-2012, 10:08 AM   #12
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
isnt it Cometic Gaskets? No 'S'?
jumpman2334 is offline   Reply With Quote
Old 05-16-2012, 10:33 AM   #13
BlueMissle sx
Ya there's no s and tits ill prolly get that done
Old 05-16-2012, 06:58 PM   #14
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
How sure are you that its a blown HG and not blown piston ring?
CLICK HERE!!!
Old 05-16-2012, 07:22 PM   #15
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
if you have low compression you should have done both a block test and a leakdown test before assuming that its a bad head gasket. you could have burned valve seats or failing piston ring seals causing your poor compression.
Old 05-16-2012, 07:42 PM   #16
Turbo Nismo
Turbo Nismo's Avatar
Trader Rating: (18)
Turbo Nismo is an unknown quantity at this point
Feedback Score: 18 reviews
To be honest, I've had two cometic head gaskets and both of them were blewn on my KA, but I can't blame them because I never resurfaced the block and I think it also had to do with the tune(timing). Know I resurfaced both and did firerings to the block also. I'm gonna try it for the last time with the cometic if I have problems again then f** it lol. As soon as I finish with my rebuild and retune I'll let you guys know.
IG: chris___s14
Turbo Nismo is offline   Reply With Quote
Old 05-16-2012, 09:24 PM   #17
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Why are people still buying shitty cometic head gaskets for ka's when cosworth makes mls gaskets for them now..?
mewantkouki is offline   Reply With Quote
Old 05-16-2012, 10:35 PM   #18
Turbo Nismo
Trader Rating: (18)
I've never tried them. If my cometic fails again I'll try it.
IG: chris___s14
Old 05-17-2012, 02:59 AM   #19
brndck
brndck's Avatar
Wow you went through all that work and had a cometic fail and then used cometic again???
Old 05-17-2012, 06:24 AM   #20
Turbo Nismo
Trader Rating: (18)
Because before the first time it happened the car overheated in the break in, but then the car was good and I dynoed it with 33 passes and did 404hp, after that the car was still perfect. Then when I tried in the street draging with two cars from 1st to 4rth gear it blew it. So I though it was by cause of it because after it when I was rebuilding it the head was very bad, so I resurfaced it, but I didn't resurface the block. I finish rebuilding, I break in it, then at dyno when the tuner is working with the timing in one pass it blew it again when reaching 368hp. When I was rebuilding it I noticed that the first pinston had the compresion rings sticked inside it and the rod was purple at the top and the piston had shrunk a lil bit. Non of my friends ever had problems with cometics and they always use them. One of them has a KA-T with 550hp and the other one has an SR with 600hp, and everyone else has high hp also and still no issues.
IG: chris___s14
