Old 05-22-2012, 11:56 PM   #1
jperez311
jperez311 is an unknown quantity at this point
Cold start squeaking, drop revs then back up again, plz read
When I start my car (mainly just cold starts mornings) I start my car then my car revs up from start, then drops like 500 then I press's the gas to keep the revs up. I gass it and it squeaks for a bit then stops then the revs are normal again. Any suggestions why this happens and if someone else experience this?
jperez311 is offline   Reply With Quote
Old 05-22-2012, 11:59 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Either loose belt or polished aluminum pulley.
Old 05-23-2012, 12:01 AM   #3
jperez311
It seems to new that I have like an extra load on my engine on cold starts. So you suggest me to get polished pulleys and loosen the belt a bit?
Old 05-23-2012, 12:10 AM   #4
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
Check your belts as you turn on the whip splash a littld water on the belts if the sound goes away you got loose belts.
S-Nation S13 is offline   Reply With Quote
Old 05-23-2012, 01:31 AM   #5
KiLLeR2001
Trader Rating: (46)
I'm saying your problem is either a loose belt or you have polished aluminum pulleys causing a squeak.
Old 05-23-2012, 01:49 AM   #6
XiaoAZN
XiaoAZN is making his/her stupidity well-knownXiaoAZN is making his/her stupidity well-knownXiaoAZN is making his/her stupidity well-knownXiaoAZN is making his/her stupidity well-known
I had the same issue. I had a lose power steering belt, tightened it and problem was solved.
XiaoAZN is offline   Reply With Quote
Old 05-23-2012, 08:56 AM   #7
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Let your car sit over night...
In the morning take off the fuel line from the fuel filter to the fuel rail...
If fuel does not gush out, you have a fuel pressure problem...
Either your injectors are leaking, your fuel pressure regulator is bad, or your fuel pump is dying...
Nikeboy355 is offline   Reply With Quote
