Old 06-09-2012, 09:18 PM   #11
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
Originally Posted by RedSled View Post
toby ,with regards to your sr20det valve cover ,how did you put fittings on it for the oil catch can
i believe you just drilled out the pipe that sticks out then you tapped the specific threading for your fittings , but how can you do it without scratching or damaging your valve cover
mines already painted
Remove the pipe or grommet that is there then tap it out for the size you need. If the hole isn't big enough then you will obviously need to drill it out to the correct size first then tap it out with the appropriate NPT tap. This method will not mess up the finish on the valve cover. Whereas if you welded on the male AN fitting, then you would need to repaint the valve cover.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
broadfield, toby
