06-11-2012, 04:11 PM | #1 |
how to jump a s14 power window motor
hello, i think my power window motor/solinoid took a crap.
I attached a wire from the positive battery terminal to the 2 wire connector going to the motor (on the passenger side door skin), I tried both of the terminals (1 goes up and 1 goes down) and neither one of them worked. Am I jumping the window motor correctly? If so, I guess the motor is dead? thanks! |
06-11-2012, 10:54 PM | #5 |
I don't think you're jumping it correctly. On my old s13 i had to put power to the window AMP. I believe the AMP works the same way as having a relay. I'm not 100% sure if this is right, but i tried different variations in that 2 wire plug (i didn't care about the motor), and i remember i had to put power in one wire, while grounding the other (**NOT SURE**) and switching it around would do the opposite to the window. Again, i'm not sure about this, so don't try it yet. Do a bit more research and you'll find what i'm talking about.
06-11-2012, 11:44 PM | #6 |
If you look at the plug for the Window motor itself (2 Wires), unplug it from the main harness and run a positive current to one wire and ground to the other. Switching the positive / ground will make it either go up or down.
I have LOTS of S13 and S14 Parts, PM me! |
06-12-2012, 07:39 AM | #7 |
Trader Rating: (55)
Feedback Score: 55 reviews
Is this your passenger side or driver. If its passenger they dont have a amp so its either u have the windows locked which you should have checked it i assume or its the window motor. If u need a new passenger window motor lmk i have one i can ship it asap.
06-12-2012, 07:50 AM | #8 |
This. If you simply run power to one wire the circuit is still open. Blue/red stripe to 12+ and blue to negative is down. Blue to 12+ and blue/ red stripe to negative is up. I do this everytime I drive my car with a electric impact battery.
