![]() Join Date: Dec 2010
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
HUGE PRICE DROP! Get these parts before the wild unicorn approaches from the east!
- If you low ball me, I won't even respond to you...simple as that.
- Please bump the thread when you view it, thank you. PBM Spacer Packs 4-lug (each pack has a set...I have two packs, so enough for all four wheels) I WILL NOT PART OUT THE SETS! - BNIB (Brand New In Box) - $150 Per Pack $280 for both (I had to wait 3 months to get these from PBM) ![]() Axxis S13 Ceramic Front Brake Pads - BNIB - $50 ![]() S14 Zenki Gauge Cluster - 87xxx miles - Perfect Shape - $75 ![]() S14 A/C Bezel - All tabs are broken - $20 ![]() SR Timing Chain Tensioner - ~3k miles - Perfect Shape - $30 ![]() Cam Angle Sensor - ~3k Miles (purchased NEW) - PERFECT SHAPE! - $130 (retails over $350) ![]() Intake and Exhaust Cam Gear Bolts - PERFECT SHAPE! - $5 each ![]() Greddy Oil Cap - PERFECT SHAPE! - $40 ![]() KU Engineering S13 Intake Manifold - Never Used (just sitting around for about 3yrs, but the last owner drilled injector port 1 larger to put larger injectors in but then sold it to me...costs about 60 to do it to the other 3 or 40 to correct port 1) - $130 ![]() SR20 Upper Oil Pan - SOLD! SR20 Oil Pump - SOLD! SR20 Oil Screens (2 sets) SR20 Rear Crank Case Cover (3) SR20 Oil Block Galley w/ Sensor (2) ![]() Unknown Brand BOV - Slightly Used - PERFECT SHAPE - $50 SR Main Cap Girdle - PERFECT SHAPE - $25 each ![]() SR Coolant Tubes - two left - PERFECT SHAPE - $20 each ![]() OEM SR20VE P11 Valvetrain (IN+EX Valves, Springs, Cams, Gears) - 15,000 Miles - PERFECT! - MAKE OFFERS ON WHAT YOU NEED! ![]() SR20DET AAC Valve (1 NEW /1 USED) - PERFECT SHAPE -NEW- $110 - SOLD! -USED- $40 ![]() stock KA24de airbox intake system and Filter is still clean (came from a 98' kouki) - PERFECT SHAPE - $75 ![]() S13 Non-ABS Driveshaft - Pick up only - Used - $100 ![]() S13 SR Transmision - Pick up only - Roughly 30k miles - PERFECT SHAPE - $150 ![]() S13 SR20 Intake Gasket - PERFECT SHAPE - $15 ![]() S13 SR20 Coil Pack Cover - PERFECT SHAPE! - $30 ![]() S13 SR Bell Housing - No cracks - $40 S13 SR Clutch Fork - Perfect Shape - $20 SR20 Water Pump - Great Shape - $30 SR20 Coilpack Gaskets - NEW - $3 each ![]() S13 SR20 Valve Cover Gasket - Perfect Shape - $20 ![]() (8) SR OEM Rocker Arm (1 Set) - Used - $5 each ![]() (16) OEM Spring, Retainer, and Keeper (1 set) (8) SR OEM Intake Valves (1 set)- SOLD (8) SR OEM Exhaust Valves (1 set)- SOLD (8) SR OEM Lifter (1 Set) - Used - $5 Each ![]() (3) SR OEM Rod - Great Shape - $10 each ![]() SR OEM Exhaust Manifold w/ Heat Shield - Perfect Shape - $40 ![]() Mr. Gasket (Copper) sr20det - SOLD! Other sr20det Exhaust Gaskets (t3, T4, Exhaust mani) - Perfect Shape - $15 ![]() Crank Pulley Bolts (2) -Perfect Shape -$5 ![]() Transmission Mount Brackets - Perfect Shape - $15 each ![]() Alternator Brackets - Perfect Shape - $25 each ![]() Knock Sensor (4)...one doesn't have a sub-harness - Perfect Shape -$30 each (20 for the one without the sub-harness) ![]() Godspeed Arm - $15 S13 Rear Links - $10 each S13 Front Lower Control Arm - $30 ![]() Thermostat Housing- $10 Coolant Temp. Sensor Housing- $10 Coolant Inlet/Outlet- $10 Each ![]() \/ \/ \/ 350Z PARTS \/ \/ \/ 350z StopTech Front BBK (was going to use them on my new build but im going with something else now. This setup retials for around $3,000) 6-Piston Front with 2-Piece Rotors - ~5k miles - $1,150 (retails for ~3k) ![]() 350z LSD - ~15k miles - $200 ![]() 350z OEM Suspension Links - ~15k miles - Perfect Shape ![]() 350z Master 1 1/16th - Perfect Shape - $45 ![]() 350z Brake Booster - Perfect Shape - $100 ![]() 350z 03' tinted tail lights - Great shape - $75 ![]() 350z OEM Fuel Tank - ~20k miles - Perfect Shape - $90 ![]() 350z Seats - ~20k miles - $300 ![]() 350z oem Radiator - ~20k miles - $100 ![]() 350z oem Radiator Support - ~20k miles - $100 ![]() These are all the make an offer items...i dont want or need them so just make an offer...pictures of these upon request. \/ \/ \/ 2005 WRX (less then 20k miles on items)\/ \/ \/ OEM Air Box Setup OEM Downpipe OEM Full Exhaust OEM Uppipe OEM Turbo Heat shield \/ \/ \/ Auto 200SX SER Engine Part Out \/ \/ \/ Head (currently has valves, springs, retainers, and keepers but can remove if buy requests) Rocker arms Oil tubes in SR head Intake and Exhaust cam gears Valve Cover EGR valve (in WORKING order) distributer (in WORKING order) Headers Injectors w/ Fuel rail Water Pump Water Pump pulley oil filter block crank pulley Intake Manifold (perfect Condition w/ all connectors and hoses) (3) Pistons (3) Rods Coolant tubes Coolant outlet Lower Oil Pan Oil Pan baffling Timing chain tensioner Flex Plate Auto trans spacer? Alternator bracket intake bracket power steering bracket ac bracket Auto 200sx Engine Harness (completely uncut) injector harness tps (throttle position sensor) Thank You For Looking! ![]()
https://instagram.com/eck_matthew/ |
