Old 06-13-2012, 06:56 PM   #1
Matman03
Matman03's Avatar
Matman03 is an unknown quantity at this point
White Smoke from SR20det
So the car started shooting white smoke anytime I hit boost. Engine temp rises and car kinda hesitates a bit. My thoughts were Head Gasket or Turbo Seal. I have a Cometic 1.5mm headgasket and ARP headstuds, does not make sense that would go out at only 18psi. But the engine temp rising is worrying me. I am sure you guys know what is going on so I leave it in your hands. Suggestions? Thanks in Advance!
Matman03 is offline   Reply With Quote
Old 06-13-2012, 07:19 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Do you have an actual water temp gauge? Stock needle gauge is utter crap.
CLICK HERE!!!
Old 06-13-2012, 07:27 PM   #3
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
I had a Cometic head gasket with ARP headstuds on my last sr20det and it had a slight head gasket leak. The Cometic gaskets don't seal very well around the bore and pressurizes the coolant system. Some people have good luck, others don't. I changed over to an OEM gasket and it never gave me any problems after that.
PM me for s13 or s14 parts!
s13 drifta is offline   Reply With Quote
Old 06-13-2012, 07:33 PM   #4
fliprayzin240sx
^^^I'd probably double check the torque on the head studs and see if they're still within spec.
CLICK HERE!!!
Old 06-13-2012, 07:43 PM   #5
Matman03
Matman03's Avatar
Yes I have an aftermarket temp gauge, normal engine load it is sitting at 220°f. Usually it sits at 180°f. Running a Koyo radiator. To the other comments, if it really the head gasket, what would you suggest. Also I guess while I am in there I should do pistons? Suggestions on that as well. Also, if it is just coolant leaking right now, about how long do I have until it has to be fixed? Thanks Guys
Old 06-13-2012, 08:11 PM   #6
fliprayzin240sx
220 is too hot. Anything over 215 and I'd be worried. Check the torque on the ARP studs, might have loosen some if you've never checked them before after you initially put them on. You're supposed to check them atleast once after you've run the engine.
If it is the HG, honestly, fresh stock HG is good. I've seen folks push 600 hp on stock HG before they start blowing them. And reason they blew wasnt due to shitty HG, but the head started lifting.
CLICK HERE!!!
Old 06-13-2012, 08:52 PM   #7
Matman03
Matman03's Avatar
fliprazin - you the man, good information to know, I guess it is time to get some replacement parts and take the car apart again! Is there a sure way to tell if it is a HG or not? I looked for oil in the coolant and coolant in the oil. That i did not see but I guess the leak could be internally where water can leak in the combustion chamber?
Old 06-13-2012, 09:10 PM   #8
fliprayzin240sx
Honestly, if I was in your shoes, this is what I would do:
- Compression check just to make see how healthy the bottom end is, should be about 140-150 psi, more is better.
- If the compression is low, drop a cap full of oil in each cylinder, if the compression jumps, rings might be going bad. If it doesnt go up, then HG might be your issue.
- I would then re torque the ARP head studs and then check the compression again. If the compression doesnt get better, then I'll start tearing down the head.
I'd get the head decked, stock Nissan HG, cooper spray the HG just for good measure and torque down with the ARP studs.
CLICK HERE!!!
Old 06-13-2012, 10:00 PM   #9
s13 drifta
s13 drifta's Avatar
Everything was good advice besides the copper spray. Do not use it, it doesn't need it.
Old 06-14-2012, 06:41 AM   #10
Rut Ro
Rut Ro's Avatar
Rut Ro is an unknown quantity at this point
Agreed with the procedure above. Make sure to gently scrape the top of the block with a razor blade edge held at a 45 degree angle to ensure all of the headgasket residue if off. I would also recheck the ARP studs aswell once its been driven approx 100 miles or so with a couple heat cycles of the engine. Glad I saw this thread. I was about to buy a Cometic HG. Copper spray isnt needed either. Good luck with the build.
Rut Ro is offline   Reply With Quote
Old 06-14-2012, 08:53 AM   #11
s13 drifta
s13 drifta's Avatar
If you want to do a metal head gasket, I recommend getting Apexi or Cosworth.
Old 06-14-2012, 03:48 PM   #12
Matman03
Matman03's Avatar
How much torque on the head studs?
This has been a great help, I read a ton on the forum but hardly ever speak up. I appreciate all of your knowledge and help.
Old 06-14-2012, 05:11 PM   #13
fliprayzin240sx
Depends on how old your fasteners are. ARP changed their installation procedures again. On the ones I'm using on my RB25, hand tight the studs in, use the lube they supply on the studs/bolts, step torqued down to 80 ft/lbs. Instructions for the older ones were different.
CLICK HERE!!!
Old 06-14-2012, 05:19 PM   #14
KendallH
KendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choices
You can also buy a test kit to check for fuel/combustion vapors in your coolant
KendallH is offline   Reply With Quote
Old 06-14-2012, 05:42 PM   #15
s13 drifta
s13 drifta's Avatar
Yeah, I have seen those, they aren't that great. A leak down test will tell you everything. Thats what I would recommend.
Old 06-14-2012, 10:02 PM   #16
240zach
240zach's Avatar
240zach is an unknown quantity at this point
an apexi hg isnt really thaaat much. just be sure to torque it down right. not just to ft lbs spec. but there is a certain order that you have to do it in as well. you have to torgue to a certain spec in a certain order, then back all them out, then torque down again, then usually you have to do it a 3rd time to full spec. and if your not going to do any block work just get an oem spec apexi hg. if you have block work done you may have to get a bigger mm hg. just my .02
240zach is offline   Reply With Quote
Old 06-15-2012, 04:58 PM   #17
Matman03
Matman03's Avatar
I would need a retune if I went with that oem thickness HG would i not? I have a 1.5mm right now
Old 06-15-2012, 08:01 PM   #18
Matman03
Matman03's Avatar
So when choosing a hg there are smaller mm like 87mm x 1.5mm what do i need? I want to go with the same thickness that I have.
Old 06-15-2012, 08:39 PM   #19
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Meh, I wouldnt worry about it. I ran a 1.5 then switched to a 1.1 because it was available.
Cosworth ftw.
di-devol is offline   Reply With Quote
Old 06-15-2012, 10:02 PM   #20
240zach
240zach's Avatar
not really. if your running a 1.5 and put on a 1.1 it would increase the compression a tid bit but nothing substantial
Old 06-16-2012, 01:09 AM   #21
zneubauer
zneubauer's Avatar
zneubauer is an unknown quantity at this point
I found its more of a precaution, like you said it doesn't need it but it doesn't hurt it at all, its that last little bit of security.
zneubauer is offline   Reply With Quote
Old 06-16-2012, 06:36 AM   #22
Matman03
Matman03's Avatar
I ordered the Apexi HG because of the HG thread. Everyone says they are the best. They are on sale right now on FSport so that was kinda good timing. Thanks everyone, I will let you know when the car is back up and running!
Old 06-16-2012, 11:00 AM   #23
240zach
240zach's Avatar
nice. apex is the shit
Old 06-16-2012, 08:56 PM   #24
overpaid4myfc
overpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choicesoverpaid4myfc has made poor choices
you can get a cheap block tester from napa ezpz
overpaid4myfc is offline   Reply With Quote
Old 06-18-2012, 08:45 AM   #25
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
i would have figured it was the seals on the turbo going out....other wise it would smoke all the time.........right?
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
