Old 05-20-2004, 01:50 PM   #1
BlackS14
BlackS14 is an unknown quantity at this point
Send a message via Yahoo to BlackS14
Flooding problem.....please help!!!!!!..longish...
SO after the car being down for close to two months, I finally recieved the set of used injectors I bought from a fellow member here on FA. I installed them yesterday along with checking any and all harnesses, bolts, nuts, ect....all seemed good so time to fire her up........no
Well I tried, but no luck. I tried for a good couple of times to get it to crank with nothing....wanted to turn, but didn't. I finally removed the old sparkplugs and they were pitch black (from when the car was running so rich during operation before teardown) and the also were wet with fuel...soaking wet. So I peer down into the cylinders and in each one there is a small pool of fuel sitting atop them.....ok......I thought maybe because I started to feather the gas towards the end of my last try caused it to flood like that.
After some careful syphoning, I got all the gas out of each cylinder and installed some new cheap plugs (I refuse to fuol out $50 worth of NGK before getting the car running right). I again tried to crank it...only twice this time for a period of three to four seconds each try....nothing. Took the fourth plug out....soaking wet with fuel....as were the other three when I removed them. More pools.....WTF??
Anyone know why this is?? I assume I installed the injectors correctly. I thought they were supposed to "pop" in, but I just pressed them down as hard as I could and then lightly tapped each one with a flathead and a hammer making sure they were secure. Could they not be seated all the way??
Also...when down...I had the fuel pressre regulator powdercoated. I don't know what the insides of a FPR consist of, but could there have been some plastic inside that could have been damged when in the oven baking???
Sorry for the long post, but I wanted folks to know the whole deal so as to help to get a possible answer sooner....Anyone have ideas????
-Bill
Once you go black you...well...you know.....lol!!!!
BlackS14 is offline   Reply With Quote
Old 05-20-2004, 02:34 PM   #2
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
um maybe cuz your not getting spark , why dont you check for that 90 percent thats your problem.. if its a sr check the ignitor and wiring, if its a ka check distributor and or coil if 91-94
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 05-20-2004, 02:38 PM   #3
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
the injectors were used like I said on IM check to be sure the O rings were good then stat checking the ignition. like charlie said on FA check your spark be sure the plugs are getting a signal.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 05-20-2004, 09:10 PM   #4
BlackS14
ill do.......I pulled the number one cylinder injector and there ws a small tear i the lower o-ring (smaller of the two).....could that cause such a massive leak???
-Bill
Old 05-21-2004, 07:16 AM   #5
Steeles
Steeles's Avatar
dunno.. replace um anyway and try again your lucks about as good as mine with these damn things bill lol.
Old 05-21-2004, 09:41 AM   #6
BlackS14
Found the problem...pulled the rail, pressurized it and injectors 1,2 and 4 were leaking like a siv.....will replace today and go from there.
-Bill
