Old 06-15-2012, 09:01 PM   #1
jdmRB2011
jdmRB2011 is an unknown quantity at this point
Help!!?? 240sx clutch doesnt want to bleed
I recently swapped my s13 and put a stage 2 disc with stock pressure player it went in fine but now the car doesn't wana get pressure to the clutch line the pedal stays down any help?
jdmRB2011 is offline   Reply With Quote
Old 06-15-2012, 09:02 PM   #2
remake94
remake94 is an unknown quantity at this point
Gah i have the same problem but in a s14
remake94 is offline   Reply With Quote
Old 06-15-2012, 09:15 PM   #3
jdmRB2011
I'm gona try something tommorow Il let you kno if it works
Old 06-15-2012, 09:20 PM   #4
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Remove the clutch damper.
Old 06-15-2012, 09:22 PM   #5
xPUNlSH3Rx
xPUNlSH3Rx is an unknown quantity at this point
Same thing happened on my s13. Got my buddy's help push the clutch while I was under the car, just make sure you unscrew the bleeder screw almost all the way out because I was being lazy by only turning it a little and it wouldn't get all the bubbles out..GL!
xPUNlSH3Rx is offline   Reply With Quote
Old 06-15-2012, 09:43 PM   #6
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
remove clutch damper x2
Old 06-15-2012, 09:50 PM   #7
remake94
I dont have a clutch damper. Hardline straight to softline.
Old 06-15-2012, 10:03 PM   #8
codyace
codyace's Avatar
Trader Rating: (58)
Keep bleeding then It does take a while in some cars, I wish I knew why myself...but it does clear up
Old 06-15-2012, 11:53 PM   #9
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
have you tried shaking your stick at it?
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 06-16-2012, 10:46 AM   #10
Bentleyness
Bentleyness is an unknown quantity at this point
Lol at these comment. It takes less then a min for the fluid to travel from master to slave. But sometime issue like this happens. Take a holes that fit into the bleeder long enough so u can use it. Then u have a guy pump the clutch while u suck the hose with the bleeder loose. Do this till I start to smell the fluid in the line. Some times it needs guiding
Bentleyness is offline   Reply With Quote
Old 06-16-2012, 11:03 AM   #11
Steinkrunk
Steinkrunk is an unknown quantity at this point
For some reason ive always had trouble bleeding my clutch. It just takes a long time, more than brakes. I use my hand to pump it up and bleed it a couple times, then when it eventually gets pressure you can use your foot. If you want to do it by yourself, use a long length of plastic hose and run it from the bleeder up to the master. Then you just pump the pedal until you only see fluid going back into the master. Then tighten the bleeder and you're all set.
http://rehopless.tumblr.com
Steinkrunk is offline   Reply With Quote
Old 06-16-2012, 11:05 AM   #12
240zach
240zach's Avatar
240zach is an unknown quantity at this point
be sure that when you bleed it to keep the pedal all the way down the open and close the valve super quick and keep pumping and restart. just don't lift up ion the pedal when the valve is open...or else your going to find yourself in the same situation. and when i replaced my clutch in my 14 sr it took like 15 minutes to bleed. lol
240zach is offline   Reply With Quote
Old 06-16-2012, 11:49 AM   #13
ka4life87
ka4life87 is an unknown quantity at this point
If its two things I hate doing on 240 is bleeding the clutch and cooling system. The best way of bleeding the clutch system after so many times of doing it is to go to the clutch pedal and loosen the rod that connects to the pedal. Unscrew it as much as possible that way when u push the clutch pedal down, it pushes the piston further and get more air out, if you dont do this its going to take forever to bleed! After u start getting some pedal, start adjusting the rod until u have about 1/4 to 1/2 inch of play on the pedal. This part suks even more, u have to drive the car around and have to keep adjusting it till u get the sweet spot, sometimes u will have too much play and clutch wont disengage all the way, other times u will have no play and clutch will slip. It takes alot of time and trial and error, I hate doing it
Any questions just ask
ka4life87 is offline   Reply With Quote
Old 06-16-2012, 01:53 PM   #14
jdmRB2011
i tried everything except removing the clutch damper which is next i really hope that works because im stressing on this damn problem my whole car is done this damn problem is the only holding me back.
Old 06-16-2012, 04:48 PM   #15
dawagarage
dawagarage's Avatar
are you depressing the pedal slowly or quickly? how many times are you pressing it. try pressing it about 30 times, slowly. keep the pedal down as you open then close the bleeder. pressing too quickly causes the fluid to froth which leads to air in the system, some say
Old 06-16-2012, 05:55 PM   #16
jdmRB2011
Got it Damn clutch dampers are useless i ran it direct
Old 06-16-2012, 06:01 PM   #17
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
take the clutch damper. get a new unit master and slave cylinder then bleed it.
i suspect a leaking master or slave cylinder tahts why is not building pressure
Old 06-17-2012, 10:42 AM   #18
jdmRB2011
It's fixed it was the clutch damper I removed it and ran the line direct.
Old 06-17-2012, 12:14 PM   #19
jdmRB2011
now its having a hard time getting into gear but once you drive it shifts good but at stops its kinda hard??
Old 06-17-2012, 05:31 PM   #20
dawagarage
dawagarage's Avatar
lol. you silly goose! i thought you already had it removed. that shoulda been your first go to.
having problems shifting into gear is also a hydraulic problem.
the solutions are the same for the problems you were having before, but also adjusting the clutch pedal. research into 'adjusting clutch pedal' that might help.
Old 06-17-2012, 08:03 PM   #21
codyace
codyace's Avatar
Trader Rating: (58)
I've had cars wehre I've used a vacuum bleeder (gotten fluid) and still had a shit pedal. Again it's not always an exact thing. Same way with brakes, you can have nice fluid and still an air pocket mid line.
