Old 06-18-2012, 11:57 PM   #1
200sx boostin
200sx boostin is an unknown quantity at this point
Help s13 redtop over heating problem
I have replaced the thermostat and water pump with proper nissan replacements. the can runs fine for the 5-10mins then starts to overheat.
Car is a S14 200sx with -
S13 Redtop
Alloy radiator
Aftermarker twin fans
Top mount T3/T4
Running 16psi
3" stright through exaust
38mm wastegate
Z32 MAF
550cc injectors
Nistune chip with tune
200sx boostin is offline   Reply With Quote
Old 06-19-2012, 12:00 AM   #2
Freakchakra
Freakchakra is an unknown quantity at this point
Check your head gasket and use the search next time.
Sent from my C771 using Tapatalk 2
Freakchakra is offline   Reply With Quote
Old 06-19-2012, 12:07 AM   #3
200sx boostin
what are the signs of a buggered headgasket ?
Old 06-19-2012, 12:36 AM   #4
801nismo104
801nismo104 is an unknown quantity at this point
do a compression test. is their coolant in your oil? or oil in your coolant?
801nismo104 is offline   Reply With Quote
Old 06-19-2012, 12:42 AM   #5
MrSanchez925
MrSanchez925 is an unknown quantity at this point
Did you burp your cooling system properly after replacing the thermostat and wp?
MrSanchez925 is offline   Reply With Quote
Old 06-19-2012, 03:17 AM   #6
200sx boostin
ok compression test 154,152,154,153 so its not the head gasket.
Sorry if this is a stupid question but what do do mean burp the cooling system
Old 06-19-2012, 03:30 AM   #7
JasianBlazin
Trader Rating: (24)
JasianBlazin is an unknown quantity at this point
Feedback Score: 24 reviews
run the car with the radiator cap off, and heater/fans on high.
JasianBlazin is offline   Reply With Quote
Old 06-19-2012, 03:34 AM   #8
Freakchakra
Also elevate the front end to so the cap is higher than the engine
overheating, overheating ecu temp
