Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
![]() Join Date: Feb 2007
Track spares: Things you might need to bring to the track!
When I first started going to drift events, I brought a ton of spare parts. Now I only bring things that I might really need.
Lets list some of the stuff you have had go bad or seen good bad at drift/road racing events. Stuff I had go bad: Inner tie rods Broken welded diff Altima fan T-bolt clamps Stuff I've seen: Broken wheel studs Spinning wheel studs Axles Turbos and the most common, the one I almost see at every event! Clutch Hydraulic issues. Almost every event someones clutch master goes out.
![]() ![]() Friends help you move. Real friends help you move bodies. |
in my opinion, t bolt clamps suck. if their sizing isnt perfect, it clamps in an oval and causes a leak.
Swap out all your T-bolts for regular worm clamps. As recommended by many tuners i meet. Also, bring: extra Arms extra axles Things people should bring but never do: Jumper cables (in case your shit dies and no one else has jumper cables and a push start wont do) voltmeter (diagnose any electrical problems) fuses electric tape (in case of fucked up fender harness or so) regular wire (in case a harness fucks up and needs to be repaired or even for general testing) |
![]() Join Date: Jun 2007
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
Helps a lot to build a 240sx ground up, with lots of quality brand new parts. I almost got $18k into my s13 now.
Some of the stuff that is to expensive to buy new, just get 2nd hand and make sure it works properly. For example, MAF, ignitor, ignition coil(s). Crank sensor |
#6 | |
I've also seen tons of broken axles, diffs, people bending SUSP arms, bent tie rods, chipped wheels etc. One thing that people tend to forget is a set of tires to drive home on. I can't tell you how many times I've seen someone leave an event with destroyed rear tires and expect to get home like that. So sketchy. |
![]() Join Date: Oct 2004
they plop off? I have only blow open 1 t clamp on a very hot day on the track, but doesn't happen often... Worm gears like destroy the silicone
![]() Join Date: Nov 2011
yeah, my 240 left me stranded a few days ago because one popped off and I left my 11mm wrench at home (which stays in my center console for that very reason but I put it in my track day bag and forgot to put it back in the car after the last event)
![]() Join Date: Sep 2006
![]() Feedback Score: 23 reviews
water. to fight dehydration and if your radiator overflows
formerly known as "hotboiblaze" ratsun: dawa (73 datsun 620) clublexus: properD (97 sc300) |
#11 | |
Bandwagon.
^^ one of the best post, i agree.
#16 |
Trader Rating: (22)
I don't know what's up with you guys having problems with T-clamps, but they are the best. Make 100% seal all around. Worm clamps DO NOT seal all the way around.
I don't know what kind of t-clamps you guys have, but I can crush my aluminum pipes with mine if I wanted to. My t-clamps are so tight they dug into silicone and are flush with silicone. And they have nylon to keep nut from spinning off. Beads on pipes is a must. After I tighten them down I test to see if pipe will come off, I put about 200lbs of pulling force on the pipe. |
#17 |
![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
Things I bring to a track day.
Extra wheels with tires already mounted - Saves TONS of time zip ties all fluids jack and 2 stands my track tool set impact gun torque wrench tons of OEM sized bolts truck and trailer - fuck driving to the track wiring stuff Most important thing I find is to spend money on quality parts and prepare before you show up at the track. Change your spark plugs and oil. Bolt check before every event and use loctite on everything. |
#18 | |
Alot of times they dont pop, but the leak slightly. Alot of people dont notice because most people dont actually pressure test their system. In comparison, worm clamps dont leak as much, and don't damage your hose as much as you would think. Quality hose isnt that weak either. T bolts can clamp tight, but they tend to clamp in an oval and allow a leak. Worms generally always clamp round. |
#19 |
T-bolts work. But for some they don't.
However, regular clamps aren't horrible. They are dependable and work well and doesnt make me worry about leaks. Can't be that bad if its on Aasbo's car ![]() |
#20 |
We've always had AAA in our family, it's saved our assess more times than I can count, especially when my brother used to have a sketchy Turbo MR2 that broke every 100 miles or so.
Question though: Has anyone actually used AAA at a track? Like can you call them and say 'Hey, I'm at such and such raceway and need a tow' or would you have to move the car? |
#21 | |
![]() Join Date: Oct 2006
![]() I laughed when I saw the spinning wheel stud in the first post, just had my first one recently ![]() ![]() |
#23 | |
i called them once but we moved the car outside of the track grounds and the first driver basically told me to fuck off so i called back and they sent a second driver who was cool and towed me. |
#24 |
![]() Join Date: Apr 2009
I've had aaa come get my car from inside a track. Not a problem in the slightest. Kind of expected actually. Wasn't even my insurance it was some dude watching. We just said he was riding with me.
#25 |
We had to tow my brothers car after needing to get it outta the house and onto a lift, and the guys from AAA asked if we had any modifications on it, after we told him no he said that they can only tow stock cars with no mods. I guess he didnt see the exhaust but for the most part he was cool. Some guys do visual inspections and one guy actually told us he would get under the car to check sometimes
#26 | |
Hell, I was in an S14 that hugged a pole once, dude towed it without asking a single question other than 'y'all kids alright? Need me to stop at the ER?'. |
#27 |
![]() Join Date: Dec 2010
Trader Rating: (42)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 42 reviews
It all depends on the driver and company. We have the right to refuse if we don't want to. Aka we dont want to damage your modified car with godspeed parts that broke and now your wheel are sitting sideways
#30 |
Bandwagon.
edgar the guy with the Z32 got his car towed from track when his motor blew, he was lowered, it was in april, i just got my car towed to a shop too, i dont know if location matters, but california is still towing lowered cars, it depends on the company i guess, but when i call in i just request for a flatbed, and done deal, AAA plus is a must, towing up to 100 miles.
