![]() Join Date: Jun 2010
![]() Hi all, i was driving my car for about a week straight no problems with the fuel pump, primed started up fine every time since i did the original install a while back.When i parked my car i left her running for about a minute the fuel pump kind of sounded louder to me.i go to start my car later that day and it bogged and died could not rev passed 1k rpm i suppose that was just the rest of the fuel getting used.This is actually my second walbro i'm going through i'm thinking about getting the aeromotive 244lph fp. let me know what you guys think.
![]() Join Date: May 2011
I've had a Walbro in my car for 2 years without an issue. Are you running the tank dry and sucking up debris or possibly have a plugged fuel filter?
http://www.youtube.com/canaanmanley |
well i also have issues with my float gauge,it goes passed empty at times and it goes up and down spontainously, it started when i installed the fuel pump and the black and gray wires came of the plug to the sending unit i fixed the wiring issue pushed the wires back into the pins and applied some solder in the plug to secure the wires , but the gauge is still experiencing issues with proper reading, maybe i need a replacement sending unit but i don't want the hassle of dropping the gas tank to replace everything if that's needed.
you don't have to drop the tank to get the sending unit out. You just need to take the top cover off the tank and pull the sender out.
![]() Join Date: Sep 2005
You've got to be able to spell the company you recommend!
You've installed 2 fuel pumps already, how hard was it? It's just maneuvering the float as in such a way, that it will not bend or bind, while taking it out and putting it in. You can test the float and gauge, while the pump assembly is out of the tank, just use caution! PS with a walbro fuel pump, 1/4 tank is the new empty!
#11 | |
![]() Join Date: Oct 2006
so i take out my fuel pump today, it was corroded with rust and and connections were corrosive as well im gonna post photos, turns out that the fuel pump was good because i tested it with leads off a battery pumped. i cleaned the the pump and sock with alchohol re installed the pump works fine but is there a way to clean out the gas tank so this wont happen again?
