Old 07-14-2012, 08:07 AM   #1
Beejis60
Beejis60 is an unknown quantity at this point
Originally Posted by Mr.J View Post
What about just removing a little material from the top of the rack house so that the AN fitting seal properly?
Though there is certainly nothing wrong with this approach, it is easier said than done. To remove it to be 100% flush, or even close to that, you will need to set it in a vise, whether for machining or for hand-grinding; and there is no good surface to clamp to for using a mill. You may be able to clamp on to the outlet/inlet ports that feed to the crossover, but then, you will need to remove material by hand since it will be out of tram with the mill.
Beejis60 is offline   Reply With Quote
