Old 07-16-2012, 11:09 PM   #1
jedi03
check clearances during oil pump change
Engine is sr20det rwd
hey got oil light on recently so replacing oil pump and cleaning passages, does anyone know which cylinder tends to dry first? i want to check my bearings and clearances and make sure theres little to no wear...
also does any one have stock main and rod bolt torque settings? just trying to get it all in one posting to make it easy! thanks guys!
Old 07-17-2012, 06:53 AM   #2
jedi03
oh and what are the clearances supposed to be on the crank shaft? too
Old 07-17-2012, 08:07 AM   #3
n240sxfnatic
n240sxfnatic's Avatar
n240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond reputen240sxfnatic has a reputation beyond repute
Get a FSM.....................
n240sxfnatic is offline   Reply With Quote
Old 07-17-2012, 06:30 PM   #4
jedi03
I don't believe dsm will cover which one goes dry first...maybe another way to ask is which cylinder failed on those that had complete oil starvation?
Old 07-17-2012, 08:18 PM   #5
blo0d
blo0d is an unknown quantity at this point
just check all the bearings... shit id just change em all, its not that expensive.
if youre going to use graded bearings the clearances should be between 1 and 2 thou... 2thou MAX! (mains), rods can go up to 3thou
and if youre getting bearings just get standard bearings, acls or something.
torque settings are 60lbs main and 33lbs rods... tighten in 2 stages
blo0d is offline   Reply With Quote
Old 07-20-2012, 12:37 AM   #6
green_pea
green_pea's Avatar
green_pea is an unknown quantity at this point
it all depends if one blocked up or not. i would be checking and replacing all if possible.
Cylinder 1 on mine died, 2,3 & 4 were all ok.
alot of info on clearances are in the S15 FSM
nationaldriftographic.blogspot.com/
green_pea is offline   Reply With Quote
Old 07-20-2012, 05:06 PM   #7
jedi03
cool, anyone have a link to one in english?
Old 07-22-2012, 10:40 PM   #8
green_pea
green_pea's Avatar
Silvia Club of NSW - Why drive when you can drift?
