Old 07-25-2012, 06:10 PM   #1
pwr-adr
pwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the rough
Lots For Sale, Manley, OS Geiken, ITB's, SPL
Need this stuff gone like yesterday!!!
Manley SR20 Connecting Rods N.I.B. rated for 800wtq- $300
BC Racing SR20 Nitride coated Int & Exh valves N.I.B.- $200
Supertech SR20 valve guides N.I.B.-$100
SR20 RWD Blacktop Complete Head, has had alot of maching work done, light P'n'P, decked, hot tanked etc, Toda 264 cams, Greddy valve springs, Tomei solid lifters and shims, circuit sports rocker arm stoppers, cam gears, valves and valve guides are stock, stock great condition valve cover included, less than 400miles on the setup and zero miles since it was resurfaced and cleaned, just needs the gap double checked on the lifters and torque down the cam caps to spec
asking just $700 for it all
Ichiba Alum Rad with Samco hoses in red- $140
GTi-R Individual Throttle Bodies, comes with TPS, plenumn and tank, vacuum canister, I can modify for RWD head, Huge jump in spool, flatter torque curve, and the best sounding SR int setup in my opinion-$200
SR20 RWD tranny, less than 1,100 miles since the rebuild, has O.S. Geiken 2nd, 3rd, and 4th upgraded gears for holding lots of trq, no grinds no kinks no whines, zero clutch kicks on it and no drifting at all just daily driving to break it in- has had alot of money and work put into it- $400
SR20 Power Steering setup, ps pump tig'd with AN fittings, power steering cooler and an alum power steering resevoir, all AN fittings and steel braided lines for the whole setup, asking just $120 for it all
Mid Mound Intercooler, tube and fine designe 18" long x 2.25" thick x 6.25 tall with a 3" wide end tanks x 6.25" tall- $60
Blitz DD Bov less than 1,100 miles on it, comes with flange and pipe-$80
Apexi Metal Headgasket, stock bore and thickness, new but has been lightly copper coated- $60
SR20 Freddy baffled extra capacity oil pans, 1 new $60, I used $40
SR20 water pump with lightweight pulley- $40
SR20 lightweight water pump pulley- $20
SR20 crankshaft, great condition- $100
SPL outer tie rod ends w/ bumpsteer adjusters, S14 inner tie rod with slip on spacers and new dust boots-$120
Blitz carbon face 2" boost gauge, measures in BAR-$40
240sx Big Brake adapter brackets, uses z32 calipers with z33/g35 big rotors, includes bolts with brackets- $40
Z32 Maf with pigtail-$40
SR20 stock connecting rods-$40
SR20 upper and lower oil pans-$40
SR20 alternator with lightweight pulley- $40
SR20 starter- $20
SR20 Cam Angle Sensors- $20
SR20 coilpacks (4)- $40 for all 4
SR20 stock cams with stock cam gears- $60
tons more parts just ask
I am willing to ship parts, I have alot more to post up and I will send all the pictures you need, Thanks Zilvia!
pwr-adr is offline   Reply With Quote
Old 07-25-2012, 06:16 PM   #2
thizzen4
Trader Rating: (22)
thizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymore
Feedback Score: 22 reviews
need power sterring set up ....asap
pm me price shipped to 98407
thizzen4 is offline   Reply With Quote
Old 07-25-2012, 06:17 PM   #3
thizzen4
Trader Rating: (22)
and a picture of the freddy oil pan used
Old 08-09-2012, 06:49 PM   #4
Shouldahadav8
Shouldahadav8's Avatar
Shouldahadav8 is an unknown quantity at this point
PM'd for MAF
Shouldahadav8 is offline   Reply With Quote
Old 08-09-2012, 08:35 PM   #5
jr_ss
Post pictures of items forsale in your original post per forum rules. Interested in the rods, need pictures.
Old 08-09-2012, 08:44 PM   #6
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
pm'd about that boost gauge.... does it include all parts to install the gauge? Sensor, wires etc. thank you.
Old 08-12-2012, 06:16 PM   #7
heiyuu
heiyuu's Avatar
heiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfectionheiyuu is close to perfection
your pm box is full
im really intereseted in the power steering setup.
heiyuu is offline   Reply With Quote
Old 08-12-2012, 08:07 PM   #8
2jdm4you
2jdm4you is an unknown quantity at this point
Pm me bout the maf
2jdm4you is offline   Reply With Quote
Old 08-12-2012, 08:24 PM   #9
E4usmc
E4usmc is an unknown quantity at this point
Pm is full bro, interested in the itb's pm me
E4usmc is offline   Reply With Quote
Old 08-12-2012, 08:35 PM   #10
filluptieu
filluptieu is an unknown quantity at this point
my number is 832 867 8701. interested in the bc valves, freddy oil pan and z32 mafs. please text me
filluptieu is offline   Reply With Quote
Old 08-14-2012, 12:12 PM   #11
georgieb88
georgieb88 is an unknown quantity at this point
Tried to pm you says your inbox is full, questions about the rods, still avaible?
georgieb88 is offline   Reply With Quote
Old 08-14-2012, 12:37 PM   #12
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Willing to split the spl outter tie rod? If yes, pm me price.
VNG704 is offline   Reply With Quote
Old 08-14-2012, 01:00 PM   #13
Edwin562
Edwin562's Avatar
im interested in the PS system, pm me your paypal.
Old 08-14-2012, 01:08 PM   #14
tx240ss
tx240ss is an unknown quantity at this point
I'll take the maf with pigtail... send paypal instructions to my pm..
tx240ss is offline   Reply With Quote
Old 08-14-2012, 01:34 PM   #15
Brandonk
Brandonk is an unknown quantity at this point
still have the power ste setup? PM me
Brandonk is offline   Reply With Quote
Old 08-14-2012, 02:29 PM   #16
camry
camry is a well-known jackass
Transmission still available? Also, are the manley rods turbo tuff?
camry is offline   Reply With Quote
Old 08-14-2012, 02:34 PM   #17
ThatS13Guy
ThatS13Guy is an unknown quantity at this point
interested in apexi head gasket, pm box full
ThatS13Guy is offline   Reply With Quote
Old 08-14-2012, 02:39 PM   #18
90S13Pilot
90S13Pilot is an unknown quantity at this point
Still have the crank?
90S13Pilot is offline   Reply With Quote
Old 08-16-2012, 06:00 AM   #19
rswails
rswails is an unknown quantity at this point
interested
PM / email sent.
rswails is offline   Reply With Quote
Old 08-16-2012, 06:13 AM   #20
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
Interested in the head gasket, valves, valve guides, and oil pan. Pix? Best pricing? Paypal ready.
Also local.
SupaDoopa is offline   Reply With Quote
Old 08-16-2012, 08:05 AM   #21
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
You're pm is full
Will you take $100 shipped to Concord NC 28025 for the crank...send me some pix
JDS Performance is offline   Reply With Quote
Old 08-16-2012, 09:17 AM   #22
silviadrag
silviadrag is an unknown quantity at this point
Pic of the mid mount setup
silviadrag is offline   Reply With Quote
Old 08-22-2012, 11:46 AM   #23
rswails
I don't think this guy is even interested in selling this stuff anymore. Have any of you guys got responses? Maybe he sold it already.
Old 08-22-2012, 04:38 PM   #24
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
well if he is ill take the trans, head, rods, valves, and maybe the gtir idividuals. pay pal ready will pay for shipping so pm me lets work out a deal. if your trying to sell
P-Funk alot is offline   Reply With Quote
