5 speed install problems
I'm installing a 91 KA and 5 speed in my formerly auto 89 240sx. I can't get the car to start. I've read the S14 swap pages but they are no help. The wiring has got to be my problem but I can't make it work. Anyone else done this on their 240?
hehe,
look at the fuse box by the battery, check under it, you'll find a two pin connector, colors (iirc) are blk/white and blk/yellow, splice them together. should fire up ![]() Last edited by Kid Zelda; 07-28-2003 at 05:19 PM.. |
I have that connector pluggen in. I swaped over the M/T transmission harness as well so everything seems to be OK as far as the starter circut. It just won't work. I did notive a blue wire that was attatched to my old ECU, does that have to be hooked up to the new ECU?
I took the engine fuse box cover off and noticed that the alt. 75A fuse was broken. I replaced it and then put the neg. terminal back on the battery and pop! It hapened again. Something isn't wired right, and help would be apriciated thanks.
I had the same problen when I did my swap. Take the alternator off and look at the place where the power cable is screwed on. There should be a plastic washer thing on there. If the theres not then it will blow the main alt fuse. Try this and let us know. P.S. It sucks too. Those fuses are $18 from nissan and I went through 4.
#9 | |
"buddy jesus"
![]() Join Date: Oct 2002
check your grounds...i had a problem with my starter wires hitting my intake manifold and it sure as hell shocked the shit out of me when my friend turned the car over...
![]() Quote:
if you guys are asking how to wire that connector behind the fuse box, SEARCH SEARCH SEARCH, I cant be too harsh as ive written a few threads asking that but search for a thread started by me a while back about 5 speed or something, somebody posted pics of it.
I was going to, but I can not think of a sig less than 75 characters. |
