Old 06-01-2004, 11:46 AM   #1
Rickrak77
Rickrak77 is an unknown quantity at this point
Cool KA24E in a MG Midget...
Hi all,
New poster here,
I've got a MG Midget that I'm in the process of installing a KA42E engine from my 90 nissan pickup (Truck got rolled, but the engine's still good).
My question is: is the intake on the 240sx any different than the intake on the pickup?
Also, is there any way to get rid of the EGR on this thing without messing up the performance (the midget is a 73 so no more smog) I already got rid of the cat and the air pump thing, but that egr tube is really in the way.
Thanks all
Rickrak77 is offline   Reply With Quote
Old 06-01-2004, 12:27 PM   #2
deviousKA
deviousKA's Avatar
deviousKA is making a name for him/her selfdeviousKA is making a name for him/her self
Send a message via AIM to deviousKA
KA powered MG very cool. Anyways yes the intake of the ka24e in 240sx is much different. The 240sx uses a plenum type intake, and is much better for performance and for your application. It bolts right on so if i were you i would try to get my hands on one.
The egr is removable, just plug all the holes for the tubes into the header, and plug the hole in the intake manifold when you remove egr control unit. It is done same way on both truck and 240, and you will not lose any performance.
Get a header for that E, it will compliment your project and shave a lot of weight. You can buy them on ebay for around 180 shipped, obx brand stainless steel. They are a good header, i run one myself.
Good Luck and be sure to show us all the finished product!
deviousKA is offline   Reply With Quote
Old 06-01-2004, 01:13 PM   #3
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
KA midget
I used to restore MGs,my only prob with them was their motorset...
Ghettokracker71 is offline   Reply With Quote
Old 06-01-2004, 05:44 PM   #4
Rickrak77
Great,
I'll look for a 240 intake, one of the problems I had with the installation was the top of the throttle body sticks up about an inch and a half out of the hood.
I can't wait till I get it on the road, it only weighs somewhere between a thousand and twelve hundred pounds with the engine installed (I won't know for sure till I get it weighed).
As for the header, I'm in the process of building one for it since there is no room for a stock header.
Since a midget is totally flat on the bottom I'm building a flat (ala nascar) exhaust system for it so I can keep the ground clearance.
I'm not going to be able to keep the stock fuel tank or the stock fuel pump so I'll have to put an inline fuel pump on it. How important is it that the fuel pressure be 43.7 PSI? (The manual says that it's pretty important, but that isn't always the case)
Thanks for the info,
Rick
Old 06-01-2004, 05:56 PM   #5
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
Irena wants to put a KA-T into a Yugo
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline   Reply With Quote
Old 06-01-2004, 06:38 PM   #6
Prok0
Prok0 will become famous soon enoughProk0 will become famous soon enoughProk0 will become famous soon enough
Send a message via AIM to Prok0
Man... Me and my brother were considering throwing a KA24DE into an MG B, we've got 3 of them sitting around here and were considering picking up a motor and droppin it in...
Got any pics of the midget?
It'll be interesting to see how the thing turns out
Prok0 is offline   Reply With Quote
Old 06-01-2004, 06:59 PM   #7
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
i wanna put one in a GEO METRO!
I am GOD!
drifterx is offline   Reply With Quote
Old 06-01-2004, 07:00 PM   #8
Rickrak77
I'm not too sure what the differences are from the mgb and the midget as far as the structure goes, but it really wasn't all that hard to get it in the car, it just took a little persuasion with a sawzall. I had to cut out the tranny crossmember and about half the tunnel but I only had to make a couple small notches in the engine compartment to get it to fit.
I'll see what I can do 'bout some pics (gotta warn you though, the car hasn't moved on it's own in about 15 years or so, so it aint pretty yet).
Can anyone tell me how critical the fuel pressure is?
Thanks 'gain
Rick
Old 06-01-2004, 07:25 PM   #9
West
OMNOMNOMNOM
West's Avatar
Yugo = RWD
Metro = FWD Crapola
Ok, sorry to take the topic off topic. Back to helping this guy.
Old 06-01-2004, 07:45 PM   #10
Zemus
Zemus's Avatar
Zemus is an unknown quantity at this point
Send a message via AIM to Zemus
Wow 1200lb sounds freaking awesome with 150+ HP mmm
Zemus is offline   Reply With Quote
Old 06-01-2004, 09:39 PM   #11
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
from what i've heard it is pretty important to have the stock fuel pressure. if you are under stock, you will be running lean and run into some problems. If you are over, you will be working the injectors harder than they are meant for. however, quite a few people have run over stock fuel pressure without any detremental effects to the injectors. A fuel pressure regulator very well might be a good idea for you.
Good luck with the car!
RBS14 is offline   Reply With Quote
Old 06-01-2004, 09:53 PM   #12
Rickrak77
Thanks,
I'll see if I can get some pics up in a couple days here.
I get the feelin' I'll be posting here quite a bit in the future.
Rick
Old 06-02-2004, 06:00 AM   #13
Ghettokracker71
KA
Originally Posted by Rickrak77
Thanks,
Rick
Come on now....you KNOW you hafta post progress reports and when your finished
Old 06-02-2004, 08:53 AM   #14
Rickrak77
Anyone see any problems with removing the EGR altogether? Would help clean up the engine compartment a bit more.
Some days you're the windshield..... Some days you're the bug.....
Old 06-02-2004, 09:28 AM   #15
RBS14
RBS14's Avatar
none whatsoever. it'll be beneficial. you save weight and clean up the engine bay. Since you don't have to have it, there is no need for it.
Old 06-02-2004, 09:43 AM   #16
Rickrak77
Cool...
Anything else you can think of that I can get rid of?
Also, what intake manifolds will fit this engine? I definitely want to go with one of the plenum types but I'm not sure which ones will work.
Thanks again.
Old 06-02-2004, 10:17 AM   #17
Salty_X
Salty_X is an unknown quantity at this point
There aren't any aftermarket KA24E intake manifolds (none for KA24DE either), so other than stock and custom.
However, Nissan Motorsports does make a KA24E manifold that allows you to run carb's (like dual 44 Mikunis, some others have used Weber 45s), but there are a lot of other parts that also need to be bought, although from the sound of it you may be buying similar parts (like a fuel pump) anyway. Plus a setup like that would be totally awesome in any car.
http://www.courtesyparts.com/nms/s13/s13_2.html
Salty_X is offline   Reply With Quote
Old 06-02-2004, 12:08 PM   #18
Ghettokracker71
Hell yeah!
Dual Mikuni 44's ?
Talk about cleanin up your engine compartment->
Old 06-02-2004, 05:39 PM   #19
mellojoe
mellojoe is an unknown quantity at this point
Yugo = RWD
Metro = FWD Crapola
What Yugo did you drive? My '87 Yugo was FWD... 4-speed, baby!
My dad has an MG-B that he's been restoring. Well, not restoring, more like rebuilding. Did you have to custom fabricate motor mounts?
We've been trying to decide on the v-8 swap... but if I ever swap my motor, and this KA is a fairly straight forward swap, we might do that.
That car is so fun to drive... and right now its only running on 3 cylinders (I believe). Can't wait to pull the engine and rebuild. But, if we pull it and swap it. Mmmmm, that WOULD be fun!
mellojoe is offline   Reply With Quote
Old 06-02-2004, 09:44 PM   #20
Ghettokracker71
Why a V8? You can get your hands on a KA24E or KADE for pretty cheap on the forums/other places. What about a CA18ET? K20A (S2K engine) ? 13B?
MGs are the best to drive....the funest part about restoring them when I used to do it was the "test driving"
Old 06-02-2004, 10:38 PM   #21
Rickrak77
I thought about putting a chevy 350 in it and almost did. I decided not to do it because it would entail a whole lot more modifications to the front end than I wanted to do. Besides, this car is gonna be a daily driver and I wanted to save some gas.
Yeah, I had to fab the motor mounts, but it wasn't all that hard. I never drove the car with the mg engine, all I ever heard about it were horror stories, so I decided the mg engine would make a better boat anchor.
Then about a year ago my wife rolled my nissan pickup (I told her next time just hit the damned dog) and I suddenly had a KA24E engine that needed a new home. (by the way, the wife was fine, not even a scratch on her. Scared the crap outa her though).
I've heard a lot of different engine designations since I've been here like s13, s14, ca14,k20a, ka24de etc. Will any of the intake manifolds off one of these engines fit on a ka24e? I would really like to get the throttle body under the hood (it sticks out of the hood about an inch and a half, without any kind of air cleaner on it).
I can't wait to drive this thing.
Old 06-03-2004, 04:31 AM   #22
brianglawson
brianglawson's Avatar
brianglawson is an unknown quantity at this point
Send a message via ICQ to brianglawson Send a message via AIM to brianglawson Send a message via Yahoo to brianglawson
i say go twin carbed, and lose some electronics put ITB's on the carbs, make your header and a nice exhaust, and man would it sound so mean...hell it would be mean too
S15 SR20DET Powered, Kouki S14 http://zilvia.net/f/showthread.php?t=578575
brianglawson is offline   Reply With Quote
Old 06-03-2004, 09:46 AM   #23
Rickrak77
Not sure what an ITB is, although I might be able to guess after awhile (prolly something to do with throttle bodies right?)
I can't remember, is the distributor advance computer controlled on this thing or not?
Old 06-03-2004, 10:34 AM   #24
BuudWeizErr
BuudWeizErr's Avatar
BuudWeizErr is an unknown quantity at this point
Send a message via AIM to BuudWeizErr
Individual Throttle Bodies
1989 Nissan 240SX, SR20DET
sillbeer.COM : phase2motortrend : Garage Works
BuudWeizErr is offline   Reply With Quote
Old 06-03-2004, 11:07 AM   #25
Var
Var's Avatar
Send a message via AIM to Var
s13 and s14 are chassis designations. s13 is 89-94 and s14 is 95-98
ka24e is SOHC and ka24de is DOHC. The ka24e was in 89-90 s13's and the ka24de was in the later models.
as far as i know only the ka24e intake will fit on the ka24e. they arent hard to find. go to a junkyard or try ebay or call around for scrap motors.
Hi
Old 06-03-2004, 11:59 AM   #26
deviousKA
deviousKA's Avatar
Yes the distributor advance is ecu driven. You will need to leave all inputs/sensors on engine in good working order, to get a decent advance curve. You have the simple option of a vacuum advance, or even an earlier electronic type advance distributor from other nissan/datsun sohc engines. This is what most do when switching to a carb setup or similar.
Ka24e with carbs and l20b vacuum distributor
If you have clearance problems like you say, you might not even be able to fit carbs (webers are a bit taller iirc?). Sticking with oem 240sx efi will give you the most room, as it sits lower than the valve cover.
Heres what itb or, individual throttle bodies, look like
Old 06-03-2004, 12:37 PM   #27
Salty_X
I think I've also read something about using a mechanical distributor out of an older Datsun motor (L28?) when running carb's, can't really remember any more though...
Old 06-03-2004, 01:39 PM   #28
allmotorKA
allmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really nice
L28 distributor is for 6 cylinders...you could change out the 6 pronged trigger wheel to a 4 pronged trigger wheel but I think you would still have to remove the drive shaft of the distributor as the L28 is gear driven and not coupled.
Best choice for junkyard distributor is from a later L20B engine like from 1979-80 as these have the electronic ignition ("matchbox") style distributor. Older distributors will use the "points" style distributor which isn't as accurate and reliable at higher RPMs as the electronic ones.
edit:
deviousKA, thanks for the compliments on my motor on a thread from last week...I tried to respond but that thread got locked/banned. Anyhow, to answer your question, I'm running 45mm ITB's as shown in the picture you just posted.
allmotorKA is offline   Reply With Quote
Old 06-03-2004, 02:05 PM   #29
deviousKA
deviousKA's Avatar
Hope you dont mind me posting your engine pic here and there and using it for reference. I am using 45mm throttles as well, with a custom intake manifold. Hope to get it finished up and installed here soon, ill probably be offering some custom parts/setups for both E, and DE.
Old 06-03-2004, 03:13 PM   #30
Ghettokracker71
Red face
Originally Posted by deviousKA
ill probably be offering some custom parts/setups for...DE.
Wonderful
