Old 08-08-2012, 03:19 PM   #1
dws180sx
dws180sx is an unknown quantity at this point
HELP! New clutch still doesnt work! SR20
Hi, couldn't find a thread that answered my question, so I hope you guys can help.
I have a 92 180sx sr20det. The clutch was slipping really bad and was shot. So I put a new clutch in (PITA with that tranny, but got it in and out), I also had put in a new clutch slave cylinder.
After bleeding the master and slave cylinder plenty times and adjusting the pushrod on the master cylinder as much as possible, the clutch is still slipping!
Any ideas what the problem is??
Thanks!!
dws180sx is offline   Reply With Quote
Old 08-08-2012, 04:35 PM   #2
canasion35
canasion35's Avatar
canasion35 is an unknown quantity at this point
i had this problem about a year ago when i did my master and slave. Are you sure you bled the clutch correctly? If not then do it again, thats what the problem was for me. Hope you get it up and running correctly again soon
R.I.P Joe Alverez
You will never be forgotten "Sky Zero"
canasion35 is offline   Reply With Quote
Old 08-08-2012, 04:45 PM   #3
Hellother
Hellother is an unknown quantity at this point
Did you resurface the flywheel? sometimes if it's warped you'll experience slipping.
Girls fighting? Where?
Is there mud and or oil involved?
Hellother is offline   Reply With Quote
Old 08-08-2012, 04:55 PM   #4
Dorifto Machine
Dorifto Machine's Avatar
Dorifto Machine is a well-known jackass
As stated make sure you resurfaced the flywheel, imperfections in the flywheel can cause some issues.
How did the Rear Main seal look when you put the new clutch in, any oil residue leaking out ?
Might or Might not be relevant to your issue ...
But check this thread out :
http://zilvia.net/f/s-chassis/452658...p-sr-swap.html
Dorifto Machine is offline   Reply With Quote
Old 08-08-2012, 11:13 PM   #5
dws180sx
Yea I'm sure I bled it correctly.
The rear main seal looked good, no leaking. As for the flywheel i Didnt get it resurfaced, It still looked good. Prob would have been smarter just to do it.
*But I was under the car today and had a buddy working the clutch, and its slipping B/C the fork doesnt have enough pressure pushing against the rod in the slave cylinder.
ex. Clutch in(down) works good, slave cylinder pushes the Fork perfect and shifting is easy. Release the clutch pedal(up) and the slave cylinder rod re-tracts but the fork pressure only pushes the rod about half the distance it should. resulting in the clutch not being fully engaged and slipping..
I'm sure i put all the springs on the fork and release bearing on properly.
Any Ideas?? Maybe the release bearing isnt pushing back easy enough? IDK
Old 08-08-2012, 11:17 PM   #6
bussitcustoms
bussitcustoms is an unknown quantity at this point
Adjust the clutch pedal itself.
bussitcustoms is offline   Reply With Quote
Old 08-09-2012, 10:26 AM   #7
KendallH
KendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choicesKendallH has made poor choices
Did you take the clutch damper out?
KendallH is offline   Reply With Quote
Old 08-09-2012, 07:06 PM   #8
repda916
repda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymorerepda916 is not welcome here anymore
Originally Posted by bussitcustoms View Post
adjust the clutch pedal itself.
winner winner winner
repda916 is offline   Reply With Quote
