Old 08-23-2012, 11:20 AM   #1501
Sil#2
Sil#2 is an unknown quantity at this point
Wondering what everyone thought on this setup:
S14 - Coilovers with a mild drop.
Varrstoens 2.2.1 - 18x9.5 +12 225/40/18 (Front)
18.10.5 +15 245/40/18 (Rear)
Would any fender work be needed? I know camber places a part, how much camber do you think I would need? Would there by any understeer? Thanks.
Sil#2 is offline   Reply With Quote
Old 08-23-2012, 11:36 PM   #1502
Turbo Nismo
Turbo Nismo's Avatar
Trader Rating: (18)
Turbo Nismo is an unknown quantity at this point
Feedback Score: 18 reviews
I amost have that same set up and I only needed to roll the rear fenders a lil bit. I have a set of gramlights 57DR 18x9.5" w225/40/18 & 18x10.5" w235/40/18 +12 offset all around.
IG: chris___s14
Turbo Nismo is offline   Reply With Quote
Old 08-24-2012, 03:00 PM   #1503
canarygarret
canarygarret's Avatar
canarygarret is an unknown quantity at this point
Send a message via MSN to canarygarret
hello, I put on my nissan s14a, XXR wheels are about 527 in 18x8.75 which should have offset to fit me well (I offer offset 20 and 35) thanks
canarygarret is offline   Reply With Quote
Old 08-24-2012, 03:22 PM   #1504
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
+20 offset
You could run a 15mm spacer on top of that depending on your tire sizes.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 08-24-2012, 03:25 PM   #1505
canarygarret
I put 225/40, did not understand what de15mm spacer, thanks
Old 08-24-2012, 03:30 PM   #1506
95KA-Turbo
95KA-Turbo's Avatar
8.75 +20 with a 15mm spacer = 8.75 +5
That should fit your S14A fine with 225/40s. You just need to roll your fenders (flatten the fender lip).
Instagram - SJKnoop
Old 08-24-2012, 03:33 PM   #1507
canarygarret
and with 8.75 +5, I would stay at the edge of the fender?
Old 08-24-2012, 04:24 PM   #1508
Breakbeat93
Breakbeat93 is an unknown quantity at this point
http://zilvia.net/f/s-chassis/420488...lp-please.html
Guy in there running the 9.75 +15 (effective) which is almost the same as your setup with 15mm spacers 8.75 +5 (effective)
As far as outer clearance anyway.
Breakbeat93 is offline   Reply With Quote
Old 08-24-2012, 04:27 PM   #1509
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
still trying to figure out the setup. have searched google this thread and fitment whore threads.
15x8 +15/+20/+40 225/60/15
anyone know if they will fit?
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline   Reply With Quote
Old 08-24-2012, 04:28 PM   #1510
Breakbeat93
Anyone running 9.5-10j up front with max angle knuckles? I'm looking to do that but I'm not sure if I'm going to run into clearance issues w lca or tie rods. My knuckles aren't installed yet so I can't really measure or get a sense of how it will work out.
Thanks
Old 08-24-2012, 04:46 PM   #1511
hoytt123
hoytt123 is an unknown quantity at this point
need some help, i wanna run 17x9 on stock body with coilovers. what offset should i run?
hoytt123 is offline   Reply With Quote
Old 08-24-2012, 04:53 PM   #1512
canarygarret
I protrudes from the front
fenders with 8.75 +5?
Old 08-24-2012, 09:16 PM   #1513
Breakbeat93
5 posts up is a link to exactly what it will look like. Pictured is 9.75 +15 which will have almost the same outside look as what you're looking to run.
Old 08-24-2012, 10:52 PM   #1514
Frankz91
Frankz91's Avatar
Frankz91 is an unknown quantity at this point
Just bought a set if Rims 17x9 +15
Wat tires are, perfect for me to put,on my S13
Going to drop my ride on coils soon want to run least amount of camber & will I have to roll my fenders
Frankz91 is offline   Reply With Quote
Old 08-25-2012, 09:06 AM   #1515
Silvi
Silvi is an unknown quantity at this point
Just bought set of wheels and i dont know which tyre profile will be the best.
The rear wheel are 18X10 tyre width will be 245
Front ones are 18X9 will be also 245
What profile is recommended?
Thanks!
Silvi is offline   Reply With Quote
Old 08-25-2012, 09:20 AM   #1516
Nategreat923
Nategreat923's Avatar
Nategreat923 is making a name for him/her selfNategreat923 is making a name for him/her self
I really like how my 215/40s fit on my 9's. There's only a little wheel bite at full lock and under spring compression.
Nategreat923 is offline   Reply With Quote
Old 08-25-2012, 10:47 AM   #1517
CRPS13
CRPS13 is an unknown quantity at this point
Thanks!
IMO it will look a little funny with more stretch in the rear. If I were doing 245's in the rear I would do a 235 in the fronts both being 35 for the profile. The stretch would be even for the most part and a 40 is just too tall again just my opinion. Also depends on what chassis you have.
CRPS13 is offline   Reply With Quote
Old 08-25-2012, 12:29 PM   #1518
canarygarret
ok,thanks
Old 08-25-2012, 02:02 PM   #1519
canarygarret
I have questions about why I put a leave with offset spacers to +5.?, and what happens if I leave +10? are deep inside?, or touch with coilovers? sorry for asking much about it, thanks
Old 08-25-2012, 07:09 PM   #1520
ray666
ray666 is an unknown quantity at this point
im a noob to wheel fitment so bare with me. i got eibach sport lines with gr-2's. will this wheel tire combo fit flush, fronts 17x8 +25 235/40 rears 17x10 +12 275/40. i also have +50 over fenders.
ray666 is offline   Reply With Quote
Old 08-25-2012, 07:24 PM   #1521
Perfect Balance
Perfect Balance's Avatar
Perfect Balance is an unknown quantity at this point
Simply put, no. The rears would sit flush on a stock body s14 with a roll/pull, and on the rear of an s13 with pull and lots of camber.
With 50mm overs, the rear will need spacers most likely, and you will have miles of space on the front. I'm not sure you can get spacers big enough to make the front flush with 50mm overs.
Which at the end of the day won't matter since you aren't low enough to have any kind of fitment anyway.
Perfect Balance is offline   Reply With Quote
Old 08-26-2012, 07:12 AM   #1522
ray666
cool. thx for the help.
Old 08-26-2012, 07:58 AM   #1523
Silvi
I dont think that the difference between 10 and 9 will be so visible.
So if i choose profile 40 with 245, when the tyre stretch the profile will be little lower?
I bought them with 285/45 the car looks like a truck with those tyres
Old 08-27-2012, 09:53 PM   #1524
Sean P.
Sean P. will become famous soon enoughSean P. will become famous soon enoughSean P. will become famous soon enoughSean P. will become famous soon enough
I've read through this whole thread just want some reassurance before I purchase.
Current setup:
16x8 (+10 or +20 not sure..) all around 195/50 ziexs
Wanted:
17x9 +12 up front running a 215/40
17x9.5 +12 in rear, should I run a 215/40 or a 215/45?
As you can see car has roll and slight pull, runs quite a bit of camber as well. Just want to make sure everything will fit fine, and the car is my daily.
Sean P. is offline   Reply With Quote
Old 08-27-2012, 10:49 PM   #1525
lscustoms
lscustoms's Avatar
lscustoms is an unknown quantity at this point
Ok insted of trying to Explain, it i did this in Paint, here is the thing... i am running the 20mm spacer on the 9 wide wheel so i clears the coils so i need at least the same back spacing on the 10 wide wheel... so what size spacer would i need?
lscustoms is offline   Reply With Quote
Old 08-28-2012, 08:59 AM   #1526
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Current setup:
http://i.imgur.com/DO3Pn.jpg
Wanted:
Depending on what kind of fitment you're looking for, all of what you said will fit. But it depends on how you want it to fit.
You could run a 45 series but that wouldn't be cool-looking now would it? Plus for a daily, I would be a tad bit more confident going a 225/235 out in the rear.
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 08-28-2012, 09:03 AM   #1527
zooopreme
Trader Rating: (38)
Originally Posted by lscustoms View Post
Ok insted of trying to Explain, it i did this in Paint, here is the thing... i am running the 20mm spacer on the 9 wide wheel so i clears the coils so i need at least the same back spacing on the 10 wide wheel... so what size spacer would i need?https://sphotos-b.xx.fbcdn.net/hphot...22568025_n.jpg
Input the numbers using the effective offset aka with the spacers on.
9" +18 (20mm spacers)
10" +18 (20mm spacers)
See the difference & compensate with new spacers.
Now go and do the math.
Old 08-28-2012, 09:56 AM   #1528
CRPS13
That is correct. When the tire stretches, the lower profile will be even lower when stretched. I would go with a 35 but thats just my preference.
Old 08-28-2012, 01:53 PM   #1529
240low
240low is an unknown quantity at this point
hey i want to buy xxr 527's and i want 17x8.25 [+25mm] in the front.. it honestly looks like anything bigger than stock will rub the springs..but i want to know if it will or not.. also in the back i want 17x9.75 [+25mm] . i would want 18's.. but unless i do a 5 lug swap they dont make the 527's in 5 lug with 18".
240low is offline   Reply With Quote
Old 08-28-2012, 01:59 PM   #1530
CRPS13
Are you on stock suspension? What chassis do you have? If s13 this is fitment with the 9.75's with a 5mm spacer all around. Will require the spacer in the front to clear coilovers but i used all around because i hate when i see the front sticking out way further with too much camber like a lot of guys on here do. Looks like ass to me.
