Old 08-31-2012, 10:37 PM   #1
Slo_lo_zenki
Slo_lo_zenki is an unknown quantity at this point
Unhappy engine too far forward....
so i finally decided to crawl under my s14 since i felt some vibrations... first sign something is wrong..... driveshaft is only 75% of the way into the transmission , WTF??? then i notice the trans mount is not bolted to the transmission.... the engine seems to be sitting about an 1.5 inches too far forward...yet engine is securely bolted to engine mounts... anyone ever seen this problem? any helpful suggestions would be great.....
maybe use a come-along and pull it back into place?
thanks in advance
Slo_lo_zenki is offline   Reply With Quote
Old 08-31-2012, 11:35 PM   #2
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
The engine is bolted in. There is no fucking way the engine can be forward 1.5 inches
Is this thread serious?
Old 08-31-2012, 11:41 PM   #3
Slo_lo_zenki
Not a joke , i am in shock as well.. checked part numbers to see if trans is from s14.... It is... It does have an r32 rear diff, i am wondering if trans mount to chasis is incorrect....
Old 08-31-2012, 11:56 PM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Pix or ban.
Old 08-31-2012, 11:58 PM   #5
Slo_lo_zenki
I will try sunday, need to change oil, so i will try to get her on a lift
Old 09-01-2012, 12:01 AM   #6
Fredy
Fredy's Avatar
Fredy is an unknown quantity at this point
If the motor mounts are bolted in, there is no way the motor can be forward. Check to see if you have the right driveshaft.
Fredy is offline   Reply With Quote
Old 09-01-2012, 12:03 AM   #7
r20crazy
r20crazy's Avatar
Trader Rating: (41)
r20crazy is an unknown quantity at this point
Feedback Score: 41 reviews
sounds like u have an auto trans mount bracket in a converted to manual car or vise versa. they are different, and will not line up by about the amount u are describing. it is unsafe to drive
Originally Posted by Your240sucks;
Dont really want to lowball you but Will you pay me too pick it up?
r20crazy is offline   Reply With Quote
Old 09-01-2012, 12:11 AM   #8
Slo_lo_zenki
Vin is for a manual, ... Does a rb swap make the trans sit further back ? My shifter is not in the right spot either.. sits too far forward in the hole .
.. my navan bumper was cut to fit a front mount at one time... And it has a skyline diff.... Makes me wonder what may have been in it before
Old 09-01-2012, 12:19 AM   #9
r20crazy
r20crazy's Avatar
Trader Rating: (41)
u need an adapter bracket if running the rb motor/trans. (this info is kinda important and shoulda been in the original posting!!!) mazworks makes the trans mount bracket adapter. if its been converted back to sr/ka maybe its still has the the rb trans mount? look at the pics and figure out what u have going on. its ur trans mount bracket in some way/shape/form
RB25 to S-Chassis (S13/S14/S15) Conversion Mounts - Engine - Mazworx
Old 09-01-2012, 12:21 AM   #10
Slo_lo_zenki
I do not have an rb trans... Wonderin if previous owner had one in it
Old 09-01-2012, 12:23 AM   #11
Slo_lo_zenki
well i will get pics as soon as i can get her on a lift....
Posted from Zilvia.net App for Android
Old 09-01-2012, 12:25 AM   #12
S14DB
AFC #1
S14DB's Avatar
What engine do you have in it?
Old 09-01-2012, 12:30 AM   #13
r20crazy
r20crazy's Avatar
Trader Rating: (41)
^ what they said. more info is needed
Old 09-01-2012, 07:47 AM   #14
Slo_lo_zenki
Stock ka24de...stock trans...
Old 09-01-2012, 07:55 AM   #15
r20crazy
r20crazy's Avatar
Trader Rating: (41)
then as i originally stated, u must have an auto trans mounting bracket in your manual car when it was thrown back to "stock" condition b4 u purchased it. u need to find the manual trans bracket and ur problems should be solved. but get the car on lift and take some pics of the trans mount situation and of the motor mounts to make sure they havent been messed with.
Old 09-01-2012, 07:59 AM   #16
Slo_lo_zenki
That was my thought too, but drive line must be from an auto or something, it isnt seated all the way into the output shaft....and i need to figure out y the shifter is way too forward in the hole..... Love dealing with hack jobs from previous owners... Weeeee
Old 09-01-2012, 08:08 AM   #17
r20crazy
r20crazy's Avatar
Trader Rating: (41)
have u owned a 240 before? the shifter doesnt sit exactly in the center of that hole for the shifter anyway, it is slightly forward. the driveshaft issue has to deal with the non stock diff. s14 driveshafts came in different lengths depending on if it had factory ABS or not because the diff housings differences. when the diff is changed the correct length driveshaft may not have been used, or u may even need a custom made 1. use the search function for this issue and u should find that answer quickly
Old 09-01-2012, 08:18 AM   #18
Arireese
Arireese is an unknown quantity at this point
probably just doesnt have the dust cap on the end of the trans.
Arireese is offline   Reply With Quote
Old 09-01-2012, 08:43 AM   #19
Slo_lo_zenki
i owned a s13 for about 6 months,,, i tore it apart, put the ka in my 510 and junked the rest..... so this is the first s chasis i plan on keeping... i have a feeling there was some hokey shit goin on with this car...... has alot of aftermarket goodies..... i will get pics asap.... oh and i knew about the abs length difference, i need to get under there and get all the part numbers i can find... ..see whats going on....
Old 09-01-2012, 10:09 AM   #20
jr_ss
What you probably has is an ABS driveshaft, which was shorter than the non-ABS cars shaft. This will make the driveshaft not look like it is in the trans all the way. We really do need pictures as well.
Stock KA has been confirmed, what trans? Auto or Man? You have an R32 diff in the car, but was the car ABS or Non-ABS from the factory?
Old 09-01-2012, 02:26 PM   #21
Slo_lo_zenki
Stock ka, stock manual.. i will look afyer work to see if it has abs. Trans mount bracket is bolted to chasis,but is about an inch from bolting to transmission...pics on sunday if wirk is slow enough to put it on a lift
Old 09-02-2012, 08:36 PM   #22
Slo_lo_zenki
not so sure the diff is skyline or not now, but its lsd, i made sure of that on the rack today...
Old 09-02-2012, 09:03 PM   #23
brndck
brndck's Avatar
Is that a dust cover of some sort around the tail shaft? That driveshaft looks like it has plenty of insertion into the trans. Keep in mind that it is designed to slide in and out slightly as the engine torques. If you're that worried about it, remove the shaft, measure how much insertion you have. As long as 75-80% of it is inserted into the trans I wouldn't worry about it. The part of the shaft that gets inserted is roughly 4 or 5" long iirc.
Old 09-02-2012, 09:30 PM   #24
Slo_lo_zenki
Yes its the dust cover, but the main worry is that the trans is not bolted the crossmember... If you look at the 4th pic down, u can kind of see that the holes are an inch off... Is that an auto crossmember?
Old 09-02-2012, 09:40 PM   #25
brndck
brndck's Avatar
Yeah most likely you have an auto trans crossmember. You should be able to pick up a used one for $50 or less. Easy to swap em out tho.
Old 09-02-2012, 09:47 PM   #26
Slo_lo_zenki
gotta keep an eye out for one..... wreckers around here are usually out of 240's craigslist it is or just fab one from scratch..easier for me than hunting...
Old 09-02-2012, 09:48 PM   #27
S14DB
AFC #1
S14DB's Avatar
There should be an directional arrow and an A or B stamped in it.
Old 09-02-2012, 09:56 PM   #28
Slo_lo_zenki
couldnt find any stampings or info on the crossmember, but if thats how far the driveline is supposed to sit in, then i will just make my own crossmember..
Old 09-02-2012, 10:16 PM   #29
Slo_lo_zenki
can the engine mounts be on the wrong way? just a curious question
Old 09-02-2012, 10:22 PM   #30
Slo_lo_zenki
well if any s14 owners out there could take a pic of their output shaft on their tranny and where is sits, that would be great
