Old 08-28-2012, 11:24 PM   #1
Zalo
Zalo is an unknown quantity at this point
KA Sputting ka24de HELP
So I got a 89 240sx with a 96 ka24de swap. Everything was running fine untill recently when I noticed the engine rocking a bit more than usual. As a precaution I stopped driving it in hopes that some one would could come help me figure it out. But after several canceled plans and no idea whats wrong I started checking out some forums and started working on little things. After all ive done the problem continues. But I felt a little more comfortable to take it for a drive. Thats when I noticed the sputtering when I accelerate and that my car accelerates slowly like theres a limiter or something. I have no clue.
So far ive done:
A throttle body cleaning
Oil change
(when i checked my oil i was running low which is mostly why i stopped driving)
Put in a new O2 sensor
My thoughts are:
Bad Idle Air Control Valve
Clogged Fuel Filter
Broken Fuel Pump
Bad ECU
Bad or clogging Fuel Injectors
Things ive checked:
Motor Mounts which was my first thought are good.
My Mass Air Flow is clean and not fried.
Problems I had before this one:
Exhaust leak
Idle control (car would cut off when coming to a stop after running for a while)(low idle almost stalling)
Takes a few times to get started after running for a while and resting a bit. (Always clicks doesn't always turns over though)
I don't have any other ideas of what it could possibly be. Im not a pro at this but ive been doing some research and figured it wouldn't help unless I ask myself and explain my unique problem. I would just get all new parts if I had the money. I figure i'd try to get some direction before I go spending money.
Thanks for taking a look and putting in some thought if you do.
Zalo is offline   Reply With Quote
Old 08-29-2012, 02:04 AM   #2
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
is the check engine light on? check what code or codes are stored if the CEL is on and start from there.
rcdad123 is offline   Reply With Quote
Old 08-29-2012, 08:30 AM   #3
Zalo
nah my check engine light is off but i plan on checking the ecu to dignosis the problem
Old 08-31-2012, 11:51 AM   #4
Zalo
So today I threw in a new Fuel Filter just to try it out and im having the same problem. -_-' I also manually checked the ECU and got a code 55 which from what I read means everything is ok.
Old 08-31-2012, 01:08 PM   #5
DonnyD
DonnyD's Avatar
DonnyD is an unknown quantity at this point
I had the same problem with no CEL leading me in any direction, it was an injector seal. I changed/replaced so many things chasing the problem, then finally it started smoking and filled the oil with gas...after that it was easy to diagnose but it did take a while to get that bad.
Cars are like Pokemon...Gotta catch em all
DonnyD is offline   Reply With Quote
Old 09-01-2012, 01:40 PM   #6
Zalo
Looks like a cheap fix ill try that out next
240sx, ka24de, s13, sputtering, swap
