Old 09-06-2012, 06:22 PM   #1
rb25_s13*CHUKI
rb25_s13*CHUKI's Avatar
Big guy friendly bucket seat thread! biggy biggy
I'm gonna make this thread for us bigger people to chime in and share your bucket seat set ups, Rail set up. Anything that involves you being 6 feet plus and not super slim around the waist! weather it be fatty fat fat or buff muscles!
What seat setup do you have in your S chassis or any car for that matter!?
Do you like to sit high in the sky? or low to the floor?
You like barley fitting in the car with your helmet?
I don't care of your seat is bolted through your damn chassis lets hear about it!
Do you like sitting nice and low and snug for great car control and comfort?
Let's see this happen! Big people unite!
Obliterate
rb25_s13*CHUKI is offline   Reply With Quote
Old 09-06-2012, 07:01 PM   #2
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
I had a buddy club with nagaisa? rails and im 6'1" and was 320lbs with a solid 42 waist and was comfortable and sat real low
S13 Hatch btw
BiG MiKE86 is offline   Reply With Quote
Old 09-06-2012, 08:00 PM   #3
rb25_s13*CHUKI
S13 Hatch btw
Any pics? I'm gonna post my pics once i finish my set up! I'm about the same as you! 6'2 300 lbs and dropping. trying to get back down to my oem weight haha, 246
Obliterate
Old 09-06-2012, 10:40 PM   #4
Perfect Balance
Perfect Balance's Avatar
Perfect Balance is an unknown quantity at this point
How the hell did you fit into a Buddy Club seat? They're like Bride Seat sized. I'm 215lb and I can't comfortably fit into one.
In any case. Nagisa Auto rails, Recaro Pole Position (barely squeezes into the rails) fits me completely comfortably. 6ft, 215lb. 36in waist.
Perfect Balance is offline   Reply With Quote
Old 09-06-2012, 10:42 PM   #5
unreal-
unreal- is an unknown quantity at this point
i also have a Buddy Club wide/Nagisa Rail Combo. Im 6'5 270 with a 38 waist. The bottom half of me fits juuuuust right in the bottom half of the seat. Its a bit snug. Top half is another story. Maybe its my build, but its very tight on the ribcage, and my shoulders rest on TOP of the wings on the side of the seat. Im slouched foward, and cant put my back flat against the seat.
Basically i wouldnt recommend the seat if you are a tall guy with a wide torso.
Nagisa rails: they are nice rails, but the buddy club wide is a bit TOO wide for the rails. It took me a solid 2-3hrs to get the seat and rails to fit in my car (S14) and line up. The specs for the rails call for a MAXIMUM seat width of 400mm. The buddy clubs are 415mm. They will fit if you loosen the bolts that mount to the seat and the bolts that mount to the chassis and kind of push the rails inwards while tightening the chassis bolts. Pain in the ass. And to make things more complicated the seat is angled a bit to the right, and its off center a bit, and i have reached maximum adjustabillity for the side mounts (the mounts themselves hit the trans tunnel side and wont adjust anymore). To make things easier i would use another rail, or custom mounts. It also interferes with the gas/trunk handle. I played with my rails enough so that i kind of wore a chunk out of the handle, so it moves freely.
Besides that, the seat is pretty comfy if your body type allows it lol.
That said, Im going to be getting a sparco EVO3 and custom mounting it in a few months. Need a bigger seat that actually FITS me and leaves a bit of room.
unreal- is offline   Reply With Quote
Old 09-06-2012, 11:00 PM   #6
TheRealSy90
TheRealSy90's Avatar
Not tall at 5'9" 250lbs but i'm not slim lol. I have a Corbeau FX1 with Nagisa Auto rails with the bucket touching the floor. In a coupe with a power sunroof.
LOL EVERYBODY HAS NAGISA RAILS.
Such a good signature.
Old 09-07-2012, 09:23 PM   #7
rb25_s13*CHUKI
The nagisa rails say they don't fit wide seats? Is this true? I'm getting a corbeau forza wide seat and still can't decide on which damn rails haha
Obliterate
Old 09-07-2012, 09:29 PM   #8
unreal-
Not really. Max width for a seat is 400mm on their site. Anything more will require some "finesse" to squeeze the seat onto the rails, or modification of the rails themselves.
Old 09-08-2012, 12:27 PM   #9
!Zar!
!Zar!'s Avatar
Bride and Nagisa rails don't go that wide. Buddyclub rails go the widest. Only problem with with going really wide is the seat sits higher since it needs to be wider than the rails.
Buddy Club, Sparco, Recaro, and Corbeau make wide seats I think.
If I had to use a wide seat, I would probably just make my own rails so the seat would sit lower.
Old 09-08-2012, 03:03 PM   #10
rb25_s13*CHUKI
Well my weight is dropping pretty fast so I'll probably pick up the standard corbeau forza seat or the fx1 so hopefully I'll be able to use the nagisa rails!
I've always just rocked s14 seats or s15 seats, I only had bucket seats once and that was in my Fc they were sparco, some small as sparcos with wedge brackets and i actually sat nicely but then again I was 240 lbs with 38-36 inch waist
Obliterate
Old 09-09-2012, 02:49 PM   #11
Jesse SR20
Jesse SR20's Avatar
Jesse SR20 is an unknown quantity at this point
Bowflex makes a seat you should check out.
J/K. I'm 6'1", 185, 34" waist. I'm running a Buddy Club wide on Bride rails. I modified the fuck out of the rails, and squeezed that seat in there. Works great, and I have plenty of hip wiggle room in the bottom end of the seat.
http://zilvia.net/f/image.php?type=sigpic&userid=64204&dateline=132878  0706
Jesse SR20 is offline   Reply With Quote
Old 09-10-2012, 07:47 AM   #12
xc0re
xc0re's Avatar
xc0re is an unknown quantity at this point
38"-40" waist and I sit comfortably in a Recaro SPG. Nagisa rails. I'd like it if the rails were a bit lower. Oh well.
xc0re is offline   Reply With Quote
Old 09-10-2012, 08:06 AM   #13
Lutz Performance
Lutz Performance is an unknown quantity at this point
6 ft even
245lbs
This is hands down the best seat i've ever used ever. Comfy to daily, and i fit like a glove in it.
Parts Sales
Email [email protected]
Phone 813 949 3540
Lutz Performance is offline   Reply With Quote
Old 09-10-2012, 08:31 AM   #14
San Diego Kouki
San Diego Kouki's Avatar
San Diego Kouki is an unknown quantity at this point
I'm buying a bride stradia reclinable soon, 5'11 220 or so lbs 34 inch waist. Anybody in one of those with a similar build?
San Diego Kouki is offline   Reply With Quote
Old 09-10-2012, 08:43 AM   #15
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
I have a NRG large bucket with buddy club rail. Im 6'1" 225lb 36" waist. Seat is comfortable but the rail makes it too high for my liking. My head almost hits the sunroof with helmet on.
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
Old 09-10-2012, 08:45 AM   #16
fullthrottle
fullthrottle's Avatar
fullthrottle is an unknown quantity at this point
this thread is for fat people you skinny douchebag haha
Sent from my SGH-T769 using Tapatalk 2
fullthrottle is offline   Reply With Quote
Old 09-10-2012, 09:01 AM   #17
irax
irax's Avatar
This thread is for Big boys..... get your pansy 5'11, 34 inch waist out of here. You can fit into every fucking seat available.
irax is offline   Reply With Quote
Old 09-10-2012, 09:33 AM   #18
driftsucky
driftsucky's Avatar
driftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond reputedriftsucky has a reputation beyond repute
I haven't seen a big dude measurement yet. Get yourself a nice 48" waist and then we can talk. My wife has spent the last 6 years ensuring that my wiast stays too large to be attractive to the opposite sex. And I haven't had a seat SINCE I've been married. Back in the day (like early 2000's), I had a Sparco seat in my Z. I'll try to find a picture of it cuz I'm sure it's scattered around my hard drive at home. It came with the car though. I was probably a 36-38 back then and it wasn't uncomfortable. The Z was my daily before kids and sh1t. It sat a bit high with my helmet. Not Top Gun Goose dies high, but if I turned my head and looked out of my window, the top of my helmet felt like it was rubbing on the headliner. Made drifting on a track a bit awkward. lol
@be_henney kranstogram is full of nonsense and foolishness.
driftsucky is offline   Reply With Quote
Old 09-10-2012, 10:01 AM   #19
rb25_s13*CHUKI
Fuck a bowflex! panzy shit right there! Free weights is the way to go!
Obliterate
Old 09-10-2012, 10:01 AM   #20
rb25_s13*CHUKI
Word need pics indeed
Obliterate
Old 09-10-2012, 11:05 AM   #21
Sleepiedaze
Sleepiedaze is an unknown quantity at this point
6'4 300pds i run a utlra shield aluminum seat. just add padding. call them give them your mesurements and BAM! custom fitted seat.
Sleepiedaze is offline   Reply With Quote
Old 09-10-2012, 12:53 PM   #22
San Diego Kouki
I weigh 220 and i bought a sparco speed but my shoulders are too broad!! Been trying to sell it back for months. Fat isnt the only kind of big. Dont hate me just because i dont sweat butter! but really though i don't wanna buy a seat that will make me a hunch back.
Old 09-10-2012, 01:51 PM   #23
driftsucky
driftsucky's Avatar
Dont hate me just because i dont sweat butter!.
I'm offended and amused.
Old 09-10-2012, 02:04 PM   #24
rb25_s13*CHUKI
Yup, that's why i said big guy bucket seat thread! Not fat people bucket seat thread haha
Obliterate
Old 09-10-2012, 02:08 PM   #25
rb25_s13*CHUKI
Big people in general not fat people only,
Obliterate
Old 09-10-2012, 02:10 PM   #26
Califunky
Califunky is an unknown quantity at this point
I used to run a pair of sparco evo xl's on customised bride rails. I'm 5'9" with (at the time) a 40" waist. Will try and find some pics but it was over 5yrs ago now.
Did about 1200 miles in a week on a holiday including a trackday @ http://www.oultonpark.co.uk/ - seats were brilliant. Really went a long way to hide the shitty roads over here
Califunky is offline   Reply With Quote
Old 09-10-2012, 02:11 PM   #27
rb25_s13*CHUKI
How tall are you?
Obliterate
Old 09-10-2012, 03:00 PM   #28
!Zar!
!Zar!'s Avatar
Waist isn't the only issue. Taller people need a seat that has the shoulders in the proper area.
Old 09-10-2012, 03:13 PM   #29
picsbypenny
picsbypenny's Avatar
picsbypenny is an unknown quantity at this point
Some circle track racer was getting rid of his stuff and gave me his seat.
Made custom rails for it, sat pretty low.
6 foot, fat(305lb)
95 RB25NEO Silvia Skid Race Thing
95 2J Dreaming 240sx Street Car
picsbypenny is offline   Reply With Quote
Old 09-10-2012, 08:17 PM   #30
Perfect Balance
I think some people in this thread don't understand how a proper fitting racing seat should feel. 42 inch waist, 320lb in a Buddy Club seat? 40 inch waist and you fit comfortably into an SPG? gtfo, there's no way you fit correctly into that seat. Is your body extremely long but only 14 inches wide or something? My friend weighs about 140lb and an SPG fit's him properly, as in snug but not tight, all the bolsters in the right place, harness holes in the proper locations, ect. I can fit into it but it's not at all properly sized for me. This is why I bought a Memory Fab S68 when they were offering them after everyone claimed that it fits 38 inch waists. I had a 36 so I bought one figuring I'd fit perfectly, only to find I couldn't fit comfortably if I had as much as a thick hoodie on.
I agree, we need pics. I can't imagine how some of you guys are fitting into these seats.
