Old 09-14-2012, 10:09 AM   #4
rotation3x
rotation3x's Avatar
rotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choices
Send a message via AIM to rotation3x
Does anyone know if the sr20det resurface limit (0.008 in) 0.2mm is specs based on still using factory headgasket or do you have to make up that space with thicker mls headgasket.
Reason im asking is because i have a feeling the head I have will need about 0.008 in decked and the block will need about 0.002 in. I dont mind running a 1.8mm headgasket. Also will I run into any issues using arp head studs after its shaved down that much.
rotation3x is offline   Reply With Quote
