#31 |
![]() Join Date: Mar 2008
Toe is really messed up in the rear, stock rucas and -2.5 camber both front and rear?
Probably has the caster set really low. really bad neg camber and small amount of caster making it twitchy at 80mph.
-Victor S. |
#32 |
![]() Join Date: Nov 2011
![]() Feedback Score: 13 reviews
I think it was, I've seen a video of a Lexus doing the same thing which turned out to be reversed PS lines.
I thinks the Power Steering problem is when you're in the highway and start turnings lets say left, then the wheel starts turning right slightly and you have to keep correcting. |
#33 |
hey idk if you solved the problem but i went through the same shit. i put new tension rods in and then car was shaking like crazy had every thing check and re checked turns out it was bad tires check that man all four of mine are bad only changed the fronts and its 95% better good luck man
#34 |
front wheel bearings? Have they been replaced?
On my DD, for the longest time I had wheel shake that came and went at highway speeds. It was never consistent, did alignments/ wheel balance, etc. nothing fixed it. Did the wheel bearings and all the shaking went away. |
#35 |
![]() Join Date: May 2008
![]() Feedback Score: 12 reviews
your problem is most likely in the rear, check ALL the solid pillow balls (rod ends) in any after market control arms you have, do this how you would check for play in a ball joint, jack up, shake wheel side to side and up and down like a mother fucker, not like a pussy, and have a friend look at each individual pillow ball on the control arms. i found my isis upper control arm had a little play in the rod end, and that was it, same problem for me. car would wanna kinda steer itself around a big turn going about over 80 ish. or it could just be your ball joints
#37 |
![]() Join Date: Jan 2008
Trader Rating: (26)
![]() Feedback Score: 26 reviews
Yeah Rear arms are all stock. I need to save for new arms. I'm love SPL arms but also thinking pbm and battle version. How are those?
Also It's not really a shake I feel it's more of a car twitches left and right and it's very unpredictable. Feels like its coming from the front. Really thinking it might be the front sway putting load on the flca. Will update when I can, times are hard can't put all my money in the car like I use to.
ಠ_ಠ |
#39 |
![]() Join Date: Dec 2010
![]() Feedback Score: 7 reviews
I'm running Fortune Auto coils too and my car has a vibration in the steering wheel during 40 to 50 MPH(Not blaming coils though).
Could be your tires though, just a thought, have them balanced? I had the studs from the hubs sticking out too far through the spacers, once i shaved them the vibration went away dramatically. BUT it's still slightly there i'm just guessing i let it on too far and it caused permanent damage to something or made my tires super bouncy. |
#40 |
Did you put in enough bumpsteer correctors when changing front tie rod ends?
They have different sizes, and you should put enough in to where the tie rod end is parellel to the LCA, if not, you are experiencing bumpsteer. |
