Old 06-11-2004, 06:37 PM   #1
nd240sx3
nd240sx3's Avatar
nd240sx3 is a well-known jackass
Send a message via AIM to nd240sx3
no clutch please help
ok i press the clutch pedal and nuthin right to the floor and stays there no presure at all but there is fluid in the resevoir whats the prob someone help please
nd240sx3 is offline   Reply With Quote
Old 06-11-2004, 09:36 PM   #2
smellslikecurry
smellslikecurry's Avatar
Trader Rating: (33)
smellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfection
Feedback Score: 33 reviews
bleed ur clutch pedal mang
smellslikecurry is offline   Reply With Quote
Old 06-12-2004, 10:11 AM   #3
INeedNewTires
INeedNewTires's Avatar
INeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond reputeINeedNewTires has a reputation beyond repute
check the bleeder valve on the slave cylinder then check all the lines especially the rubber line cause it could have cracked. Check for leaks, check integrity of reservoir and seals on M/c and S/c. Just check over the whole hydraulic system its not hard, if you gotta replace something then do it! just dive in, get dirty, its the only way anything ever gets fixed.
INeedNewTires is offline   Reply With Quote
Old 06-12-2004, 10:14 AM   #4
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
bleed your clutch!!! haha almost positive thats u'r problem
89 240 SR powered...
ummm i promise its stock
TheSparo is offline   Reply With Quote
Old 06-12-2004, 12:44 PM   #5
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
hmm... u mighta have to adjust ur clutch pedal.. when u press it in, does it pop back out? can you shift through the gears or no? lay down under ur steering wheel and look under ur pedal. see if theres any fluid leaking. look at the metal piece going into the firewall. the end of it pointing towards ur seat should have maybe 1cm of threading. hope this helps
DJ_Sunrise is offline   Reply With Quote
