Old 10-18-2012, 10:46 PM   #1
Supergoji
Supergoji's Avatar
Supergoji is an unknown quantity at this point
Send a message via AIM to Supergoji
Wheels, SR, VVL, KA, Z32, Z33, OEM & aftermarket
Body Kit
S13 BN type 2 body kit SOLD
Wheels/brakes/hubs
Front 17x8/ Rear 17x9 work stitch wheels $600
Front 18x8.5/ Rear 18x9.5 SSR integral A2 $1,400
front 16x7.5/ rear 16x8.5 $250 Z32 twin turbo set
all around 16x8.5 Z32 Twin turbo wheels Chrome $450
240sx 5 lug conversion $250
180sx brakes x2 $75 each
S13 4 lugs front hubs $15
S13 front knuckles $20
350Z items
cloth seats with s13 rails $350
Z32 items
intake
Upper and lower twin turbo plenum $150
Custom 2.5" intercooler with dual inlet/outlet $200 (great for 2jz, RB, VG swaps)
Throttle bodies $30 each
N62 Twin turbo MAF $50
Engine/accs
Twin turbo under drive pulley $70
Timing covers $100
2 sets of Twin turbo heads $220 each set
1 Set of non turbo heads $150
2 Twin turbo blocks w/cranks, pistons, rods $300 each block
2 set of 4 Cam Gears$40 each set
1 set of 4 cams 5spd $200
1 set of 4 cams auto $180
2 twin turbo Power steering pumps w/ brackets $50 each
electrical
EFI harness connectors w/ pigtails $8 per
90 PTU $30
3 twin turbo alternators $50 each
tons of coilpacks $15 per
Trans/Clutch/Diff
Non turbo RPS flywheel/clutch/pressure plate $380
5 spd trans $200 Great for RB25 swaps
Twin turbo Rear end, brakes, suspension, wheels, diff etc. $450
Exhaust
2 sets of twin turbo manifolds $30 each
Specialty Z 2+2 catback $500
audio
Zenclosure for 10'' sub on driver side $60
500 wat Amp $60
Tons of interior parts
Fuel
1990 fuel rail $40
old style Nissan side feed
6x 270cc $180
6x 370cc $220
New style side feed
6x 370cc $350
I have tons of interior Z32 items, all interior panels I have are Charcoal (black)
240/180 items
KA
Engine
KA starter $25
#10 ecu 5spd $30
3x KA coils + ignition $25 each
KA24de Throttle body $25
oil pan sold
plug wires $5
Power steering
2x PS resi $30each
Transmission
Mount $10
VVL
SR throttle body $20
IACV $20
water sensor housing $5
SR20DET
oil pan x2 $20 each
oil pan baffle x3 $5 each
crank baffle x2 $5 each
water pump $sold
throttle body sold
thermo outlet x2 $5 each
s13 SR water neck $5
thermo housing x3 $5 each
water temkp sensor housing x2 $25
fuel rail sold
exhaust mani x2 $40 each
clutch fan (minus the fan just the clutch part) sold
water pump pulley sold
dipstick tubes x2 $5
cross over tube $5
oil catch can OEM x2 $15 each
intake manifold bracket $5
knock sensor x3 $20
oil return tube $5
power steering mount bracket sold
alternator mount adjuster $5
timing chain tensioner x3 sold
oil filter housing x3 $15 each
clutch slave $5
oil pump drive $5
timing chain gear $5
IACV sold
Alternator bracket 20
power steering mount $12
starter sold
MAF sold
upper & lower intake mani $30
HKS 90 degree filter pipe $15
redtop 02 sensor SOLD
radiator $50 (aftermarket jdm)
S13 block w/ crank $150
eagle rods w/ bearings $320
SR20VE head SOLD
CAS sold
E5 ecu x 2 SOLD
62 ecu x 2 SOLD
Megan Down pipe sold
HKS down pipe SOLD
s13 sr20 redtop motorset w/o turbo $1,400
SR EVO 8 turbo setup $620
s13 power doors $150
s13 wingless hatch x2 100 each
s13 popup hood x2 $75 each
S13 gas tank $50
s13 RUCA's pair $20
S14 toe arms $20
S13 front LCA's x2 pairs $30 each
S13 manual doors $60
S13 tension arm brackets $30
S13 front cross member x2 $40 each
S13 rear subframe x2 $50 each
S13 carpet $50
S14 carpet $50
S13 Tein Tension Arms $80
S13 SR koyo Radiator sold
Bee*R rev limiter $200
S14 steering rack $75
S13 hicas steering rack $100
S13 welded diff $75
S13 brake pedal x3 $40 each
S13 clutch pedal x2 $40 each
S13 5spd driveshaft x2 $100 each
Personal (wooden) steering wheel $100
screamer Pipe SOLD
S13 A pillar panel $10
S13 gauge cluster surround x 4 $20 each
S13 shifter trim $10
S13 kick panels $15
S13 glove box $15
S13 center console x 2 $30 each
S13 steering wheel shrouds x 4 $20 each
S13 hvac $40
electronic items have been tested and are in working shape
sold as is
no refunds sorry
Willing to ship
add 3% for Paypal
914 382 2116
[email protected]
First come first serve. $ talks.
Sent from my SPH-L710 using Tapatalk 2
www.NYZC.net
Supergoji is offline   Reply With Quote
Old 10-18-2012, 11:02 PM   #2
oero_ballin16
oero_ballin16 is an unknown quantity at this point
got any pics?
oero_ballin16 is offline   Reply With Quote
Old 10-18-2012, 11:59 PM   #3
Supergoji
Supergoji's Avatar
Yes, what are you looking for
www.NYZC.net
Old 10-19-2012, 12:09 AM   #4
efaustin
efaustin is an unknown quantity at this point
interested in the s13 koyo radiator pm me price shipped to 43055 would like pics also thanks
efaustin is offline   Reply With Quote
Old 10-19-2012, 05:34 AM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Info on the vvl head. P11? P12? Complete or bare? Has cams? Pix?
Old 10-19-2012, 07:30 AM   #6
Supergoji
Supergoji's Avatar
Efaustin and brndck pm's sent
www.NYZC.net
Old 10-19-2012, 11:39 AM   #7
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
PM Sent Sir
2muchboost is offline   Reply With Quote
Old 10-19-2012, 05:35 PM   #8
Trinidrift3
Trinidrift3's Avatar
Trinidrift3 is an unknown quantity at this point
interested in the s13 wheel shrouds. pictures?
Trinidrift3 is offline   Reply With Quote
Old 10-19-2012, 06:06 PM   #9
Mike - E
Mike - E's Avatar
Trader Rating: (40)
Mike - E is an unknown quantity at this point
Feedback Score: 40 reviews
bumpers, legit dude and parts. just picked some up for my s13
Mike - E is offline   Reply With Quote
Old 10-20-2012, 01:00 PM   #10
Supergoji
Supergoji's Avatar
all pms responded!
the wheel shrouds are for the steering column
they look like this
http://autotechimports.com/inside/up...12DSCF1620.JPG
(not my picture) but mine are all clean
www.NYZC.net
Old 10-20-2012, 04:28 PM   #11
epik1
epik1 is an unknown quantity at this point
interested in works wheels if you're willing to ship to canada
epik1 is offline   Reply With Quote
Old 10-22-2012, 03:58 PM   #12
Supergoji
Supergoji's Avatar
I have received all texts and pm's, I will respond tonight. I have been extremely busy.
www.NYZC.net
Old 10-22-2012, 04:08 PM   #13
whaapshh
whaapshh's Avatar
whaapshh is an unknown quantity at this point
Pictures of the work stitch wheels?
Please like my Facebook page facebook.com/magikmovement
whaapshh is offline   Reply With Quote
Old 10-23-2012, 07:28 AM   #14
2muchboost
Trader Rating: (33)
Waiting on z32 non-chrome wheel pix whenever you get a chance.
Old 10-23-2012, 07:43 AM   #15
g35gabby
g35gabby's Avatar
Trader Rating: (26)
g35gabby is an unknown quantity at this point
Feedback Score: 26 reviews
g35gabby is offline   Reply With Quote
Old 10-23-2012, 07:55 AM   #16
fiascoelment
fiascoelment's Avatar
fiascoelment is an unknown quantity at this point
Can you pm me pics of the 5 lug conversion
fiascoelment is offline   Reply With Quote
Old 10-24-2012, 05:20 PM   #17
Supergoji
Supergoji's Avatar
all sold items shipped
list updated
and all pms replied!
www.NYZC.net
Old 10-25-2012, 07:45 PM   #18
mr2thomas
mr2thomas is an unknown quantity at this point
i sent payment for knuckles!
mr2thomas is offline   Reply With Quote
Old 10-27-2012, 02:36 AM   #19
penco
penco is an unknown quantity at this point
Pics of the cas?
penco is offline   Reply With Quote
Old 10-27-2012, 12:55 PM   #20
s14newb
s14newb is an unknown quantity at this point
I bought ecus from you. One was burnt up and one has a daughterboard installed that you failed to mention. You refuse to fix this.... Fix it.
s14newb is offline   Reply With Quote
Old 10-27-2012, 01:06 PM   #21
Supergoji
Supergoji's Avatar
all ecu's were tested and were working fine
daughter board i was unaware of
i will accept the daughter board ecu back but the "burnt one" is on you as they all worked fine before shipping out
www.NYZC.net
Old 10-27-2012, 04:36 PM   #22
s14newb
No. The burnt one isn't on me. It's on you. You sent it to me, you take it back. You say you checked them, but yet you were unaware that one has a daughterboard.
Clearly burnt. Even has solder to the left on the one pin like someone would have tried to fix it at one point.
Clearly a daughterboard installed.
Old 10-27-2012, 05:55 PM   #23
Mike - E
Mike - E's Avatar
Trader Rating: (40)
damn that's crazy, he was testing them when i went to pick up my part so i was interested in one but he didn't have a J4, he indeed did test em out in front of me, i was gonna buy one to resale it on the bay.
Old 10-27-2012, 05:59 PM   #24
Supergoji
Supergoji's Avatar
as seen above
i put them in my car one at a time and drove around block with them
they worked fine
all of them were also given a full throttle rip down the street
they all worked fine when they left my possession
like i said i will take back the daughter board ecu no problem
www.NYZC.net
Old 10-27-2012, 05:59 PM   #25
s14newb
yeah, I'm at school so its yet to go in any car or mine. but it can easily seen by opening it that its junk.... and the fact that he didn't know one had a daughterboard is telling me that he didn't check any.
Old 10-27-2012, 06:00 PM   #26
s14newb
Its all in paypal's hands now...
Old 10-27-2012, 06:04 PM   #27
Supergoji
Supergoji's Avatar
i TEST inside car by DRIVING with it
i have spoke to paypal and informed them that everything was sold as is which was stated at the bottem of my post
if you like i can involve the witness that saw all 4 of the ecu's working fine
www.NYZC.net
Old 10-27-2012, 06:06 PM   #28
s14newb
Involve him if you would like....
Old 10-30-2012, 11:02 AM   #29
SrS13=MuchLove
SrS13=MuchLove is an unknown quantity at this point
Which intake manifold bracket is it? The small one bolts up to the alternator bracket or the larger one that bolts up on the block? Ship to ga?
SrS13=MuchLove is offline   Reply With Quote
Old 11-01-2012, 03:52 PM   #30
Supergoji
Supergoji's Avatar
i have both
which do you need and sure ill ship
www.NYZC.net
