Old 10-21-2012, 07:52 PM   #1
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Are SOHC and DOHC chassis harnesses the same?
I just got an 89 hatch with seriously fucked up wiring so I was just going to swap all the wiring from my 93 hatch into it. The fuse box harness and the chassis harness.
If I swap both of these into my SOHC shell it's pretty much like changing it into a DOHC shell correct? So I can just drop a KA24DE in and roll with it?
StryfeS13 is offline   Reply With Quote
Old 10-23-2012, 01:03 PM   #2
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Anyone know?
Old 10-23-2012, 01:40 PM   #3
h2v7
h2v7 is an unknown quantity at this point
short answer is a no.
Let me google that for you
you would have to take like most/all sohc wiring out and replace it with dohc. as well as your ka24de.
the speedometor and stuff will not work you need a DOHC cluster.
h2v7 is offline   Reply With Quote
Old 10-23-2012, 02:03 PM   #4
Krusty_s13
Krusty_s13's Avatar
Krusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud of
i am running a dohc interior and dash harness with a sohc chassis harness on my fastback. drive it everyday with working ac and all. plugged it up and did the reverse of the dash plug wiring for a sohc to dohc.
Krusty_s13 is offline   Reply With Quote
Old 10-23-2012, 09:29 PM   #5
StryfeS13
It's Always Broken.
StryfeS13's Avatar
Im swapping the whole chassis harness out of a dohc. Also has dohc cluster and fuse box engine bay harness.. so that is all dohc wiring, shouldn't it work?
Old 10-23-2012, 09:36 PM   #6
StryfeS13
It's Always Broken.
StryfeS13's Avatar
By dohc interior and dash harness do you mean the harness that goes under the dash and into the engine bay?
Cause isnt there only the fusebox harness that is in the engine bay that goes under the wheel wells and under the dash, and then the actual chassis harness which goes back to the taillights? Cause i planned on swapping both.
Old 10-25-2012, 12:05 AM   #7
StryfeS13
It's Always Broken.
StryfeS13's Avatar
So does anyone know? I'm about to spend $175 on a fuse box harness and really don't want it to be a waste.
Old 10-25-2012, 05:34 AM   #8
jr_ss
Apparently you haven't researched this at all. Come on man!
KA24e to KA24de swap - Step-by-step. : 240sx Articles
Old 10-25-2012, 08:26 AM   #9
h2v7
if you have de wiring and cluster n ecu and so on and engine pull it all and put it in the other car and bam.
